02-06-2012, 10:43 PM
#81 (permalink)
Originally Posted by mans
I'd love to remove all engine accessories, however I can only remove the alt and engine water pump...
I kinda need my power steering and a/c
(please understand this, although I'm not sure how people survived without a/c in their cars during those summers before car a/c became popular in the 70's-80's. hey they must have had a/c in those horse drawn carriages in the 1800's too cuz the summers were hot then as well and how can u survive without a/c.. ye we're spoiled today :-))
is it possible to convert the power steering and a/c to 12v electric as well?
I think electric power steering is one of those really tricky things, most cars are opting for hydraulic for the better feel. However the new BRZ/FRS/86 is supposed to have an amazing electric steering rack. You could probably reduce the speed of the hydraulic pump to reduce the power consumption of the steering.
As for A/C, you could have A/C only turn on when idling/engine braking. BMW's new mild hybrid system basically uses the idea that we can power all accessories with a small portion of energy lost to braking.
02-07-2012, 01:36 AM
#82 (permalink)
Grrr :-)
remember I am talking about a 94 XFI
NO power steering pump and NO AC
the ONLY accessories I have are alternator and water pump. so for me nothing else changes.
I am replacing the crank pulley with an aluminum pulley. this will lighten my rotational mass quite a bit and I can still "put" a belt on if I really need too.
YES I agree sometimes just too hot without AC learned that the hard way in the metro last summer.
thats why I am getting a tracker as soon as I can. so when it "REALLY" is just too hot to be without AC I can drive the tracker.
if you really want to go electric steering this is probably easier than you think.
you ONLY need to power the steering pump while not moving or moving slowly. once your at highway speed there is flat out NO reason to run the power steering pump. even not intended to be manual cars are usually pretty easy to steer at highway speeds on smaller lighter cars. I would confirm this first though :-)
BUT if you running a car with all this stuff you need to make sure of the kind of typical POWER DRAW your going to experience. remember a metro is a power sipper. the electric water pump takes about as much power as "the rest of the car" takes ie not much.
Lights are an issue which is why I am going LED including the headlights if I can figure out how to cheaply and legally :-)
the BLOWER is the biggest issue. when its damp out IE foggy windows you have to use the blower and heat (no ac remember) and its a power PIG :-)
02-08-2012, 10:12 PM
#83 (permalink)
If any one had a diesel they could use water injection to further down size their cooling system needs.
02-09-2012, 09:43 AM
#84 (permalink)
I'm not sure how hard it would be to modify the pullies - but how about rigging the PS and alternator up to a clutch setup? Like the AC Compressor. Maneuvering in parking spots, engage the PS pump as soon as you're moving, disengage it. Same for the alternator. Start the vehicle, let the alternator run for a minute to charge the battery back up then disengage. Going down the highway just monitor the usage.
The water pump could possibly be rigged up to a viscous fan clutch. The faster the motor spins, the slower the pump spins. At 2000 RPM with it almost disengaged, it can probably move enough water to keep "hot spots" from forming.
The Following User Says Thank You to Miller88 For This Useful Post:
02-10-2012, 11:26 AM
#85 (permalink)
Definately a Modder!
Back to the original topic, VW, Audi, mercedes and other manufacturers make an auxillary 12 volt coolant pump. The VW ones in particular(and perhaps others) use magnetic coupling from the motor to the impeller itself, so that reduces the chance of leaks developing. I don't see why you couldn't run 2 or 3 in parallel and use some electronics to control when they turn on. You could run one continuously, and kick in the others when needed or some similar setup. I always wanted to get my hands on one of these!
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
07-28-2012, 02:02 PM
#86 (permalink)
Mag Tipid sa Gasolina
Does the electric motor for the water pump has to vary RPM speed depending on engine RPM?
Or does it simply run at a fixed rpm when it runs?
The fan blades do pose some load too.
Thank you
01-24-2013, 03:49 PM
#87 (permalink)
This modification has been done on a 2005 Toyota Echo.
See the thread : Echo-Troll Modding Thread (2005 Toyota Echo)
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
02-20-2019, 09:35 PM
#88 (permalink)
Are there any developments in this field.
Most of the links in this thread have gone dead.
Brushless dc motors have really come down in price, and 3d printers have also become somewhat common among people who like to tinker. Just curious what is/can be done now.
06-30-2019, 08:02 PM
#89 (permalink)
EWP
I had an EWP on my 2005 GTO for a couple years,
it was documented to free up 15-18 wheel HorsePower, but that's on a 400hp car
I liked it because it was great at cooling down the car between races (I could run it with the engine off)
the thermostat only determines if the coolant is going thru the radiator, coolant is still moving thru the block and heater core in most vehicles even when the thermostat is closed
id imagine if you're freeing up 5% horsepower, you're going to see some of that in the fuel economy
the problem that I ran into,
most EWP's aren't really rated for the kind of use it'll see in a street vehicle, they are probably only good for a few years (mine lasted about 2 before I sent it in to the manufacturer for rebuild)
Meziere stood behind there product, even polished it up before sending it back to me
https://www.meziere.com
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
06-30-2019, 09:24 PM
#90 (permalink)
I still say belt drive the water pump and do an alt delete.
