Old 06-30-2019, 09:32 PM   #91 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I still say belt drive the water pump and do an alt delete.
I agree with this completely. The water pump is really critical to the survival of the engine. Add first take all the other parasitic draws off the engine. Power steering, alternator, air conditioner.
Old 07-15-2019, 11:19 PM   #92 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I see new cars having 2 pumps. One mechanical and one electric. Have they put the smallest pump possible and then use electric when needed?
Old 07-16-2019, 07:07 AM   #93 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
The auxiliary pump is there to circulate coolant after shut down. The mechanical pump is variable so no need to boost it with an electric one.
Old 07-17-2019, 04:14 AM   #94 (permalink)
teoman's Avatar
A3 - '12 Audi A3
They claim that it speeds up warmup time.
Old 07-18-2019, 11:00 PM   #95 (permalink)
ASV
weirdo
ASV's Avatar
in my Tacoma truck I always wanted to move the radiator and the battery to the bed.
I had manual steering and it seemed that the lighter the front end the less effort I needed in the parking lot. it originally had power steering but the pump broke same with the ac
I think an electric water pump would have helped.
that was a stripped down truck
Old 08-10-2019, 03:35 PM   #96 (permalink)
Davies Craig Electric pump + their PWM waterpump and fan controller..
Good stuff isn't cheap,,
If it has a motor its worth playing with.......
Old 05-08-2022, 03:49 PM   #97 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Came accross a summary of a scientific paper (published in J. Eng. Gas Turbines Power. Jan 2007, 129(1): 239-244):
Application of Controllable Electric Coolant Pump for Fuel Economy and Cooling Performance Improvement
Haven't read the article, but here is the summary:
The engine cooling system for a typical class 3 pickup truck with a medium duty diesel engine was modeled with a commercial code, GT-Cool, in order to explore the benefit of a controllable electric pump on the cooling performance and the pump operation. As the first step, the cooling system model with a conventional mechanical coolant pump was validated with experimental data. After the model validation, the mechanical pump submodel was replaced with the electric pump submodel, and then the potential benefit of the electric pump on fuel economy was investigated with the simulation. Based on coolant flow analysis, a modified thermostat hysteresis was proposed to reduce the recirculating flow and the electric pump effort. It was also demonstrated that the radiator size could be reduced without any cooling performance penalty by replacing the mechanical pump with the electric pump. The predicted results indicate that the cooling system with the electric pump can dramatically reduce the pump power consumption during the FTP 74 driving schedule and that the radiator can be downsized by more than 27% of the original size, under the grade load condition.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Logic (10-26-2022)
Converting power steering to electric power steering Daox EcoModding Central 54 01-17-2017 06:16 PM
Electric assist for SUV? Tony Raine EcoModding Central 8 10-15-2012 08:17 PM
“Revenge of the Electric Car” Coming in 2009 SVOboy EcoModder Blog Discussion 18 03-28-2012 07:24 PM
Turning off electric hot water heater when not home? ZachUA Saving@Home 33 12-09-2009 09:51 AM
Article: Electric Subaru Due in 2009, One Year Early MetroMPG Fossil Fuel Free 8 08-29-2009 12:19 AM
