05-30-2014, 01:43 PM
#501 (permalink)
Prius - '16 Toyota Prius Three
However, that engine really is ancient, and I doubt that they could hit their fuel economy targets with it, even adding sequential port injection (which the turbo and I think 4-cylinder versions had).
Also, I think the only engine still being produced in that family is a 1.0 DOHC 4-cylinder for Pakistan. Not exactly my choice for maximum fuel efficiency.
05-30-2014, 10:32 PM
#502 (permalink)
Sure the G-series engine is kinda outdated, but is still not really a bad option at all. A 12-valve head would be a good improvement, alongside MPFI which was only available for the turbocharged versions. It actually seems to make sense to use the G-series because of its light weight and a good throttle response for an engine at its displacement class.
05-30-2014, 10:39 PM
#503 (permalink)
White Whale - '03 Chrysler Town & Country mini van all white
Took a bit too long for me. I was happy with a small Aspire about 6 years ago and wanted an Elio 6 years ago; but more large SUVs, RVs, pickups and delivery vans were crowding roads more and more - very quickly. Worried me enough to jump from 40 m.p.g. to a 20 m.p.g. pickup. I doubt I could go back to "small".
05-31-2014, 08:22 AM
#504 (permalink)
Rat Racer
A rotating yellow light on the roof and a placard on the back ought to buy you some space.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
05-31-2014, 12:53 PM
#505 (permalink)
The 'Confined Space' warning sign would be appropriate. A multicolor paint scheme helps as well. I have driven all sizes of car and light/medium trucks safely. There is a myth that mass alone makes a vehicle safe. The design geometry and materials used are crucial to passenger protection. Trucks take longer to stop than a sedan. Most cars and light trucks weigh around 3500 lb. If you are truly worried about crash protection then wear a helmet and knee pads.
05-31-2014, 02:29 PM
#506 (permalink)
I drive with my Army-issued body armor.
Well, I did, once...
06-01-2014, 12:06 AM
#507 (permalink)
I've been known to drive with a neck brace when needed. I'd tell everyone that it's like the HANS things that NASCAR drivers wear.
Christopher Jordan -- My friends made that transition ... after they got T-boned. :shrugs:
06-01-2014, 08:33 PM
#508 (permalink)
Maybe they should buy the rights to the old BMW K75 fuel injected 3 ? Smooth, torquey and 75 hp. Not bad fuel consumption either.
The Following User Says Thank You to PeterS For This Useful Post:
06-02-2014, 03:28 PM
#509 (permalink)
Too busy for gas stations
Turtle - '92 Honda Civic Vx Team Honda 90 day: 67.09 mpg (US) Rolla - '10 Toyota Corolla Le Beast - '91 Chevy V2500 Bus - '01 VW Eurovan MV Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous 90 day: 53.09 mpg (US) Cal - '68 Ford Mustang GT/CS
Shouldn't be meet m/c standards.
DF60A Lean Burn | Suzuki GB Marine
On off the shelf unit is the best solution, even Tucker had to go this route.
Shooting for 600 miles of range at 65-70 mph out of a vx.
06-03-2014, 12:23 AM
#510 (permalink)
Got me thinking about fitting the entire driveline of a Russian IMZ-Ural motorcycle into an Elio. Well, even the newer water-cooled engine in the R1200 would be an interesting option...
