2008-04-22 |
318 |
6.95 |
$3.38 |
45.76 |
"PHX-Fontana CA" |
2008-04-23 |
467 |
11.01 |
$3.74 |
42.42 |
"Fontana CA to San Jose CA" |
2008-06-16 |
9.97 |
$4.41 |
32.6 |
"San Jose" |
2008-07-17 |
153 |
4.68 |
$4.36 |
32.69 |
"San Jose" |
2008-07-20 |
291 |
7.36 |
39.54 |
"San Jose to Reno" |
2008-08-21 |
423 |
10.37 |
$3.98 |
40.79 |
"Reno to San Jose then commute 4 weeks" |
2008-09-30 |
10.69 |
$3.54 |
35.55 |
"San Jose" |
2008-12-02 |
351 |
10.92 |
$1.79 |
32.14 |
"San Jose" |
2009-02-05 |
318 |
9.64 |
$2.05 |
32.99 |
"San Jose" |
2009-02-20 |
123 |
3.8 |
$2.11 |
32.37 |
"San Jose" |
2009-02-26 |
390 |
9.74 |
$2.1 |
40.04 |
"Monteray weekend" |
2009-04-23 |
354 |
10.34 |
$2.18 |
34.24 |
"San Jose" |
2009-06-30 |
370 |
10.13 |
$2.63 |
36.53 |
"San Jose" |
2009-08-06 |
438 |
10.84 |
40.41 |
"San Jose
Begining of tank put VX rims and 155/80/13 on rear.
6 lbs each of rotating mass.
End of tank change oil with 0-30W" |
2009-10-06 |
462 |
11.19 |
$2.73 |
41.29 |
"(San Jose) Second tank with ScanGuage so calibrated. It was off by 2.7% (ScanGuage showed 10.9 gal actually put in 11.2)" |
2009-12-15 |
11.22 |
$2.78 |
37.43 |
"Ave speed 22mph. All commute. No Mods - but started EOC. Digital Odometer so when key is off no readings. Learned that at the end of tank and started turning key back to on. Maybe 10-30 more miles in EOC (arbitrarily added 10 miles to distance) really 410 not 420. Adjusted scanguage to 8.7% error. Day after fillup installed lower grill block." |
2010-02-04 |
443 |
10.83 |
40.9 |
"4 trips to Morgan Hill this tank.
ScanGuage(tank) said 40.0 mpg, 10.8 gallon, 434 Miles, 27 MPH Ave. Reduced scanguage error to 7.8%
Begining of tank Lower grill block." |
2010-03-24 |
455 |
11.06 |
$2.96 |
41.14 |
"Odo 455, SG 445 10.6 gallons SG
perdiction. Updated SG to 10.8.
AVG this tank 25 mph SG MPG = 41.9
During this tank removed passenger Wipper and removed driver airbag. 3lbs total." |
2010-05-18 |
440 |
10.67 |
41.24 |
"Scanguage reset itself when moving battery. So reset SG to defaults and put in tank size and engine size again. No offset and lost previous calibration." |
2010-06-22 |
474 |
11.08 |
42.78 |
"SG said 459 miles, ODO = 474 miles. Maybe adjust speed setting on SG? Or figure out who is right with GPS.
During last tank electrical problem so SG lost settings. Had to reset at begining of previous tank. So this time adjusted fuel by 6%. SG also said 24 MPH on tank. During this tank put VX rims on front, redid lower grill block, finished battery move and install cooling fan light." |
2010-07-21 |
514 |
11.49 |
$3.06 |
44.73 |
"SG said 501 miles 29 MPH ave 44.2 mpg 11.3 gallons
Odo said 514.2. Subtracting mileage 514.
Updated sg to 5% offset.
Really 10.998 gallons after 2nd click. But added 0.5 gallon since when I got in it showed not quite Full.
Right before fill up removed cold air inlet from air filter box. Now just getting engine compartment air. So when cooling fan is on temp of air is 95-110." |
2010-08-17 |
467 |
10.11 |
46.19 |
"Actually 10.608 but subtracted 0.5 gallon from last tank adjustment.
SG = 456miles 28 MPH ave tank, 44.6 mpg on SG
This tank removed 17lbs or so, removed cold air intake, also at start of tank drove to Morgan Hill a couple of times. SG updated to 3.9% adjustment factor." |
2010-09-28 |
526 |
12.11 |
$2.9 |
43.44 |
"Odo said 526.1 miles.
SG says: 43.1 mpg, 514 miles, 25 mph avg.
So SG says 12 less miles then ODO. Is it off or is it EOC where SG goes off and odo keeps up (key back on).
Update SG to 4.7% adjustment for fuel usage.
SG predicted 11.9 update to 12.0 (half the distance) End of tank got both Moonies on back wheels (v2.0) - also version 1 of belly pan" |
2010-11-02 |
545 |
12.09 |
$3.06 |
45.08 |
"This tank did some P&G.
Odo said 545 miles. SG said 514 miles so Glide 30 miles.
SG said tank ave mph = 29
12.0 gallons used.
Change fuel type to hybrid after fill up. See what happens when P&G now.
No adjustments to SG fuel fillup. Predicted 12.1 and achieved 12.1 so still 4.7% offset." |
2011-01-19 |
393 |
9.47 |
$3.22 |
41.5 |
"Car sat for 8 weeks 11/20 - 1/18
SG Said 40.6 tank mpg. But fuel fill up of 9.5 predicted and observed. Early fillup before mileage run." |
2011-02-08 |
528 |
10.98 |
$3.3 |
48.09 |
"Put 250 mile of hypermiling down 101 and back first part of tank.
SG said 522 miles, 11.2 gallons, 34 mph ave, 46.3mpg. Adjusted SG to 11.1 gallons (split difference)
During this tank, removed passanger mirror. Started rear wheel skirts but did not finish yet." |
2011-04-15 |
464 |
10.89 |
$4.06 |
42.61 |
"ODO 464
SG 457miles, 43.3mpg, 10.5gallon, 25mph ave. Updated 10.5gallon expected to 10.6gallon actual." |
2011-05-25 |
510 |
10.69 |
$3.96 |
47.71 |
"ODO = 510.1 miles
SG = 504 miles, 10.8 gal 27 mph ave, 46.6mpq" |
2011-07-11 |
512 |
$3.68 |
49.23 |
"Odo 511.7 miles.
SG =47.9 mpg, 10.5 gallon, 505miles, 23mph ave. Changed calibration to 2%.
During this tank did front airdam." |
2011-08-16 |
528 |
10.39 |
$3.62 |
50.82 |
"Odo = 528 miles. Sg = 521 miles, 10.1 gal, 22 mph ave, 51.3mpg. During this tank put ATF+4 in tranmission and changed oil wih 0w-20." |
2011-10-04 |
520 |
10.432 |
$3.719 |
49.85 |
"Odo said 520.6 miles.
SG 514 miles, 26 mph ave, 50.2 mpg, 10.2 gal.
At end of tank put driver seat back in and started to pack tools and spare tires into car." |
2011-11-04 |
511 |
10.96 |
46.62 |
"SG said 45.1 mpg, 11.1gal, 504 miles, 24mph ave. This tank I added about 100 lbs to weight of car because I packed my tools for moving. Also first week of tank was cold/rainy here in Bay area." |
2011-11-16 |
254 |
5.1 |
$3.64 |
49.8 |
"Last fillup before drive to Detroit. Odo said 254 miles. SG = 49.5 mpg, 5.06 gal, 251 miles, 31mph ave." |
2011-11-18 |
290 |
6.018 |
48.19 |
"Fillup in Sparks NV. Just outside Reno. Costco in Reno did not have gas. Odo = 113173
SG = 49mpg, 5.86 gal, 287 mile, 45mph ave. This was drive from San Jose to Reno. No P&G." |
2011-11-18 |
548 |
10.257 |
$3.25 |
53.43 |
"Odo = 113721 548 miles. Drive from Sparks NV to Salt Lake City. SG = 10.4 gal, 52mpg, 545 miles, 56 mph ave. Only P&G about 1/2 hour of 11 hour drive. Measured course along 80 near bonneville, My odo had 0.1 to 0.2 miles longer then 5 mile course." |
2011-11-20 |
466 |
9.03 |
$3.26 |
51.61 |
"Odo = 114187, SG = 52.1mpg, 8.84gal, 462mi, 45mph ave. Lots of snow leaving Salt Lake. Had to slow down. Lots of areas with black ice and I averaged 35-40 those areas. Other areas sun melted ice and drove through an inch of slush. (Lots of drag). So overall did alright. Pictures of slush,snow covered car on blog." |
2011-11-20 |
513 |
$3 |
49.33 |
"Council Bluffs IA, Odo = 114700. SG = m47.5 mpg, 10.6 gal, 508 miles, 59 mph ave. Cold with wind out of the south, sometimes 50mph, tried to put some miles on the car so didn't stop and kept speed up." |
2011-11-21 |
477 |
9.845 |
48.45 |
"Odo = 115177. SG = 474 miles, 54 mph ave, 48.2 mpg. P&G for 2 hours between Council Bluffs and Des Moines. But the outside temp was in the 20's. Also still had lots of ice/snow in whell wells. Trip from Des Moines to Joiliet Il was clear but cold. Also lost the 2nd half of under body panel somewhere between Council Bluffs and Des Moines. (It wasn't there when I left des moines Bluffs in the morning)" |
2011-12-03 |
474 |
10.733 |
44.16 |
"Odo = 115651, first 1/2 tank from Joiliet IL ti Detroit. Last part of tank to/from work/airport here in dtw. SG - 46.2 mpg, 10.1 gal, 470 miles, 38 mph ave. At end of tank put passanger wipper back on." |
2011-12-17 |
416 |
10.02 |
$3.099 |
41.52 |
"do=116067 , SG=39.7 mpg, 23 mph, 410 miles, 10.3 gallon. About 200 miles driving around looking at condo's/townhouses and apts. Driving through parking lots and looking at neighborhoods not looking at traffic and anticipating. Other 200 miles driving to/from work and airport. Average outside temp 30F - 0C. Still have an extra 100lbs in trunk of tools and stuff." |
2012-01-26 |
371 |
9.516 |
$3.12 |
38.99 |
"Odo said 371 miles (116832). SG = 37.4 mpg, 9.76 gal, 366 miles, 26 mph ave. Two trips to airport = 50 miles at 45mpg, rest of trips are to/from work, 5 miles. Average temp for 3 weeks 32F, 0C. I.E. half the time I got in the car when less then freezing, half the time above freezing. 5 miles to work average 1.5 miles untill closed loop 3 miles till engine temp > 150F." |
2012-02-13 |
415 |
10.654 |
$3.349 |
38.95 |
"One trip to airport. Rest back/forth work. Average temp 30F. Odo 117247. SG = 38.0 mpg, 10.7 gal, 409 miles, 27mph ave." |
2012-03-12 |
447 |
11.021 |
$3.849 |
40.56 |
"Odo 117694. SG data not available. Disconnected battery during this tank so SG data is not for the entire tank. Starting to warm up." |
2012-04-06 |
466 |
10.42 |
44.72 |
"Odo=118160 SG = 31mph ave, starting to warm up." |
2012-05-09 |
423 |
9.365 |
45.17 |
"Odo 118583, SG 44.4 mpg, 9.25 gal, 411 miles, 29mph ave. Temps warming up here in Detroit." |
2012-06-08 |
499 |
10.5 |
$3.589 |
47.52 |
"Odo 119082, SG 29mph ave, 489miles, 10.5 gal, 46.4mpg" |
2012-06-29 |
522 |
9.76 |
53.48 |
"Odo 119082, SG 52.5mpg, 9.77gal, 513miles, 36mph ave, 3 long brewpub trips." |
2012-06-30 |
547 |
9.44 |
57.94 |
"Clyde OH. Drove to Pittsburg and back. Odo = 120151, SG=53.4mph, 10.1gal, 540miles, 48mph ave." |
2012-07-27 |
530 |
11.1 |
$3.56 |
47.75 |
"odo=120681, sg=48.7 mpg, 10.6 gal, 521 miles, 33 mph ave. Changed fuel filter so lost about a cup of fuel. Also first 150 miles is rest of trip from pittsburg." |
2012-08-29 |
531 |
11.07 |
$3.909 |
47.97 |
"odo 121212, SG=46.6mpg, 11.1gal, 519miles, 36 mph ave." |
2012-09-24 |
468 |
9.805 |
47.73 |
"ODO 121680. Engine heaters installed but not used yet. SG 45.4mpg, 10.0 gal, 455miles, 29mph ave." |
2012-10-24 |
433 |
9.23 |
46.91 |
"Odo=122113, SG=46.4mpg, 9.0gal, 418miles, 35mph ave." |
2012-12-06 |
401 |
9.21 |
$3.369 |
43.54 |
"Odo=122514, SG= 43.1mpg, 9.1gal, 393miles, 31mph ave. Starting to get cold in MI." |
2013-01-17 |
416 |
10.11 |
$3.15 |
41.15 |
"Odo = 122930, SG 41.3mpg, 9.81gal, 406miles, 28mph ave. Cold here in Detroit." |
2013-02-13 |
9.97 |
38.62 |
"Odo 123315 SG: 37.9mpg, 10.0gal, 379miles, 29mph ave. Got cold here" |
2013-03-14 |
9.23 |
$3.589 |
44.85 |
"Odo = 123729 SG: 44.4mpg, 9.13gal, 405miles, 32mph ave, 1 trip to lansing and back to get average up." |
2013-04-09 |
397 |
8.9 |
$2.45 |
44.61 |
"Odo 124126, SG 43.3mpg, 8.95 gal, 388miles, 29mph ave" |
2013-05-22 |
499 |
9.649 |
51.72 |
"Odo 124625, SG 48.4mpg, 10.1 gal, 491 miles, 33mph ave. Two trips to DTW and 1 trip FNT." |
2013-06-17 |
469 |
8.98 |
$3.749 |
52.23 |
"odo 125094, SG said 51.2mpg, 8.92 gal, 457 miles, 32 mph ave." |
2013-07-14 |
599 |
11.12 |
53.87 |
"odo 125693
sg 51.9mpg, 11.2 gal, 585 miles, 34 mph ave" |
2013-08-13 |
577 |
10.79 |
$3.4 |
53.48 |
"ODO 126270, SG52.1mpg, 10.7gal, 558 miles, 31mph ave." |
2013-10-09 |
508 |
10.473 |
$3.3 |
48.51 |
"Odo 126778, SG 48.2mpg, 10.2 gal, 496miles, 29mph ave." |
2013-11-06 |
421 |
9.07 |
$3.09 |
46.42 |
"odo 127199, sg 48.1mpg, 8.55gal, 412miles, 29mph ave." |
2013-12-16 |
427 |
9.993 |
$3.099 |
42.73 |
"Odo 127626, SG 45mpg, 9.29gal, 419 miles, 31mph ave." |
2014-01-28 |
376 |
9.15 |
$3.15 |
41.09 |
"Odo 128002, SG 40.6mpg, 9.07 gal, 369 miles, 27mph ave. Some subzero driving snow on car and roads. Too cold to shut off at lights." |
2014-03-04 |
433 |
10.52 |
41.16 |
"Odo 128435, SG 40.6mpg, 27mph ave, 10.5 gal, 430 miles. Snow and warm up at airport." |
2014-04-02 |
464 |
10.836 |
42.82 |
"Odo 128899, SG 43.1mpg, 10.3 gal, 448 miles, 29 mph ave." |
2014-06-02 |
514 |
10.96 |
46.9 |
"Odo 129413 miles, SG 47.5 mpg, 10.6 gal, 506 miles, 30mph ave." |
2014-06-06 |
580 |
10.77 |
$3.389 |
53.85 |
"Odo 129993. 59 miles on trip counter when I left apartment in Detroit. SG 50.5 mpg, 11.3 gal, 574 miles, 50mph ave. Fillup at Costco in middle of Iowa" |
2014-06-07 |
269 |
4.96 |
$3.44 |
54.23 |
"Odo 130262. SG 57mph ave, 52.3mpg, 5.1 gal, 267 miles. Filled up at Omaha Nebraska." |
2014-06-07 |
501 |
$3.4 |
49.12 |
"Odo 130763. SG 60mph ave, 50.8mpg, 9.77 gal, 497 miles. Fillup in Cheyenne WY." |
2014-06-08 |
473 |
7.86 |
$3.51 |
60.18 |
"Odo 131236. SG 58 mph ave, 54.8mpg. Fillup at Costco in Salt Lake City." |
2014-06-08 |
508 |
$3.96 |
50.45 |
"Odo 131744. SG 526 miles, 59 mph ave, 55.4 mpg, 9.48 gal. Fillup at Reno NV. When got to office next morning Odo at 132037." |
2014-07-23 |
534 |
11.159 |
47.85 |
"ODO 132278, SG 49.4 mpg, 10.0 gal, 494 miles, 32 mph ave. Reno to SC then driving around SC for 3 weeks." |
2014-10-01 |
489 |
10.33 |
47.34 |
"Odo 132767, SG 42.5mpg. 11.1 gal, 475 miles, 22mph ave. Middle of tank switched SG to hybrid mode to keep running on engine off coasting." |
2014-12-05 |
428 |
10.541 |
$10.54 |
40.6 |
"SG 40.7mpg, 10.3 gal, 420miles, 20mph ave. odo=133195" |
2014-12-15 |
693 |
15.33 |
45.21 |
"Topped off 100 mile tank before I did a Santa Barbara and back 590 mile trip. Odo = 133888.
SG reset because of new tires and Battery installed 12/13/14. 155/80/13 on front and back. Perviously had 175/70/13s in front. round trip was 48.5mpg" |
2015-02-26 |
389 |
10.715 |
$2.66 |
36.3 |
"Still loose wire somewhere reseting SG. Odo 134277" |
2015-05-07 |
10.04 |
$3.25 |
37.95 |
2015-07-22 |
495 |
11.9 |
$3.16 |
41.6 |
2015-10-07 |
394 |
$2.52 |
38.63 |
"Odo 135547 SG still out." |
2016-01-05 |
400 |
11.18 |
$2.5 |
35.78 |
"Odo 135847. SG still broken" |
2016-02-16 |
9.51 |
$1.989 |
43.53 |
"Odo = 136351 SG still broken." |
2016-03-30 |
435 |
10.62 |
$2.47 |
40.96 |
"Odo = 136796. SG still broken" |
2016-06-09 |
403 |
9.78 |
$2.42 |
41.21 |
"Odo = 137199. Fixed SG 5/20/16 first fill with SG working." |
2016-08-29 |
454 |
10.345 |
$2.36 |
43.89 |
"Odo 137653 SG 44.4mpg, 10.0gal, 448miles, 29pmh ave." |
2016-10-27 |
10.08 |
41.07 |
2017-01-06 |
441 |
10.65 |
41.41 |
"Took SG home to read codes on PT." |
2017-06-13 |
193 |
5.14 |
$2.38 |
37.55 |
"Fill up before drive back to Tucson. SG said 40.3mpg, 4.72gallon, 27mphave" |
2017-06-17 |
462 |
8.97 |
$2 |
51.51 |
"San Jose to San Bernadito CA. SG 49.8mpg, 9.19gallon, 41mphave." |
