2011-10-20 |
351 |
$3.38 |
34.41 |
"First fill up I did on my brand new car. Literally new. Only 700 miles on the car." |
2011-10-27 |
341.8 |
9.8 |
$3.37 |
34.88 |
2011-11-02 |
366.9 |
$3.33 |
36.43 |
2011-11-13 |
311.6 |
8.46 |
$3.34 |
36.83 |
2011-11-16 |
318.8 |
8.685 |
$3.33 |
36.71 |
2011-11-18 |
355.7 |
10.262 |
$3.14 |
34.66 |
"did higher speed highway driving this tank. 55 mph is definitely better than 70mph. I really need to work on the Aero for this car, but I need to talk the wife into letting me." |
2011-11-20 |
348.8 |
9.211 |
$3.38 |
37.87 |
2011-11-23 |
320.2 |
9.19 |
$3.39 |
34.84 |
2011-12-04 |
368.4 |
9.803 |
$3.12 |
37.58 |
2011-12-14 |
335.4 |
8.927 |
$3.18 |
37.57 |
2011-12-19 |
$3.17 |
37.74 |
"first tank with the Ultra Gauge. Hoping to improve mileage and wok on P&G." |
2011-12-22 |
311.2 |
7.814 |
$3.18 |
39.83 |
"work commuting. Worked on P&G some. Engine on coasting. Cannot do Engine off without shutting the computer down for a few seconds which throws off the calculations." |
2011-12-29 |
429 |
11.111 |
$3.17 |
38.61 |
"I had to do a partial fill on this tank to make it to payday. I did log all miles traveled and the partial fill amount. The numbers reflect actual miles and gallons filled from this tank." |
2012-01-06 |
368.5 |
10.04 |
$3.4 |
36.7 |
"work commuting. Colder temperatures this tank." |
2012-01-17 |
227.5 |
6.016 |
$3.4 |
37.82 |
"I did a short fill so I can finally calibrate my Ultra-Gauge. Commuting back and forth to work. Car was in body shop for a week getting some repairs done after a guy backed into the front of it." |
2012-01-20 |
327.8 |
9.073 |
$3.38 |
36.13 |
2012-01-25 |
350.4 |
9.295 |
$3.4 |
37.7 |
2012-01-31 |
361.7 |
8.927 |
$3.56 |
40.52 |
2012-02-14 |
398.3 |
11.009 |
$3.58 |
36.18 |
"commuting back and forth from work." |
2012-02-21 |
377.4 |
9.838 |
$3.69 |
38.36 |
"commuting with some running around town." |
2012-02-25 |
404.5 |
10.684 |
$3.75 |
37.86 |
2012-03-01 |
393.3 |
9.724 |
$3.76 |
40.45 |
2012-03-21 |
408.7 |
10.398 |
39.31 |
2012-04-24 |
338.4 |
36.39 |
2012-04-30 |
485.1 |
12.495 |
$3.71 |
38.82 |
"I had to do a short fill last Friday and put 2 gallons in. Filled it up today and topped it off. I am liking the warmer temps, at least for gas mileage. Of course without tint, the cabin gets real warm." |
2012-05-04 |
406.8 |
10.637 |
$3.66 |
38.24 |
2012-05-09 |
347.3 |
9.247 |
$3.62 |
37.56 |
2012-06-04 |
468.1 |
13.11 |
$3.4 |
35.71 |
2012-06-11 |
383.3 |
9.723 |
$3.43 |
39.42 |
"had a #2 cylinder misfire code pop up. Put in some fuel injector cleaner and filled up with 89 octane from a different station than I normally use. I am hoping this will clean up the system and prevent further maintenance." |
2012-06-15 |
396.6 |
9.877 |
40.15 |
"Last tank was 89 Octane. I don't know if it helped, but the misfire in #2 cylinder error went away." |
2012-06-20 |
394.3 |
9.012 |
43.75 |
2012-06-25 |
401.8 |
10.32 |
38.93 |
"When I filled up last time, I do not believe I got a full tank in. That is likely the reason for the bump in the last tanks fuel mileage. I had to run the air conditioner quite a bit this tank because of high temps and all the glass I have in my vehicle. Hopefully I will get the windows tinted soon so I do not have to run the a/c as much." |
2012-10-05 |
387.5 |
10.179 |
$3.73 |
38.07 |
"First tank I went through since I returned. I was gone for a while. My wife drove the car a bit, but she doesn't track mileage at all." |
2012-10-10 |
437.5 |
10.54 |
$3.75 |
41.51 |
2012-10-16 |
407.6 |
9.343 |
$3.75 |
43.63 |
"Don't think I got this tank all the way full. The pump was continually shutting off despite normal fueling procedures." |
2012-10-24 |
436.8 |
11.053 |
$3.39 |
39.52 |
2012-11-06 |
380.9 |
9.614 |
39.62 |
2012-11-06 |
348.8 |
9.502 |
$3.289 |
36.71 |
2012-11-16 |
411 |
10.714 |
$3.36 |
38.36 |
2012-11-30 |
361.8 |
9.105 |
$3.3 |
39.74 |
2012-12-05 |
350.1 |
9.739 |
$3.3 |
35.95 |
"I don't believe the last fill up was all the way full. My Ultra Gauge showed 38.7 mpg." |
2012-12-11 |
377.7 |
9.852 |
38.34 |
2012-12-14 |
389.5 |
9.974 |
$3.27 |
39.05 |
"Not sure the tank got all the way full on this fillup. the pump shut off a few times will trying to fill the tank. I will see on the next tank. UG showed 36.9mpg for this tank." |
2012-12-20 |
364.5 |
10.193 |
$3.21 |
35.76 |
2013-01-08 |
317.4 |
8.342 |
$3.34 |
38.05 |
2013-01-18 |
600 |
15.911 |
$3.51 |
37.71 |
2013-01-24 |
324.4 |
8.798 |
$3.349 |
36.87 |
2013-02-01 |
363 |
9.471 |
38.33 |
2013-02-15 |
354.5 |
9.014 |
$3.68 |
39.33 |
2013-03-01 |
338 |
9.03 |
$3.76 |
37.43 |
2013-03-05 |
9.091 |
$3.7 |
37.4 |
2013-03-08 |
7.4 |
$3.7 |
39.46 |
2013-03-13 |
319.9 |
8.337 |
$3.67 |
38.37 |
2013-03-19 |
301.9 |
7.845 |
$3.66 |
38.48 |
2013-04-03 |
383.6 |
9.613 |
39.9 |
2013-04-12 |
405.5 |
10.317 |
$3.38 |
39.3 |
"first full tank with the new tires and 40psi" |
2013-04-17 |
321.2 |
8.112 |
$3.3 |
39.6 |
2013-04-23 |
365.7 |
9.055 |
$3.28 |
40.39 |
2013-04-26 |
389.1 |
9.918 |
39.23 |
2013-05-03 |
301.2 |
7.47 |
$3.27 |
40.32 |
2013-05-08 |
320.1 |
7.978 |
$3.25 |
40.12 |
2013-05-13 |
7.714 |
$3.45 |
40.45 |
2013-05-17 |
334.1 |
8.717 |
38.33 |
"I am not sure how accurate this fill up was. The pump would not pump fast enough to do a shut off so I had to manually stop the pump right before it started overfilling." |
2013-05-23 |
408.1 |
9.886 |
$3.43 |
41.28 |
2013-05-25 |
122.6 |
3.318 |
$3.44 |
36.95 |
"This was near the beginning of a 1300 mile tip. Running highway speed limits." |
2013-05-25 |
278.1 |
8.286 |
$3.44 |
33.56 |
2013-05-25 |
292.1 |
8.753 |
$3.39 |
33.37 |
2013-05-26 |
148.5 |
4.341 |
34.21 |
2013-05-26 |
266.3 |
7.714 |
$3.37 |
34.52 |
2013-06-01 |
299.5 |
8.883 |
$3.169 |
33.72 |
2013-06-01 |
300.6 |
8.047 |
37.36 |
2013-06-02 |
288.5 |
7.402 |
38.98 |
2013-06-02 |
319.3 |
8.778 |
36.38 |
2013-06-05 |
332.5 |
8.684 |
$3.39 |
38.29 |
2013-06-07 |
337 |
8.411 |
$3.39 |
40.07 |
2013-06-11 |
400.8 |
10.355 |
$3.489 |
38.71 |
2013-06-13 |
9.383 |
$3.47 |
38.26 |
2013-06-19 |
380.3 |
9.2 |
$3.45 |
41.34 |
2013-06-24 |
375.8 |
9.647 |
$3.45 |
38.96 |
2013-06-27 |
328.2 |
8.092 |
$3.36 |
40.56 |
2013-07-13 |
8.09 |
40.17 |
2013-07-21 |
350.9 |
9.014 |
38.93 |
2013-07-22 |
332.8 |
8.205 |
40.56 |
2013-07-25 |
322.2 |
7.722 |
41.72 |
2013-07-31 |
9.695 |
$3.489 |
42.7 |
"This tank was great. Wonderful warm weather and I starting using my highest gear at slower speeds which boosted mileage through the small towns I drive through and the base. So hopefully I will build on this, but I am about to take a long trip which will require traveling at higher speeds." |
2013-08-16 |
358.2 |
9.017 |
39.72 |
2013-08-17 |
352.1 |
9.466 |
37.2 |
2013-08-18 |
365.8 |
9.351 |
$3.439 |
39.12 |
2013-08-22 |
404.4 |
10.115 |
39.98 |
2013-08-28 |
417.8 |
10.517 |
39.73 |
2013-09-19 |
347.7 |
8.625 |
40.31 |
2013-09-25 |
396.8 |
10.129 |
$3.25 |
39.17 |
2013-09-30 |
388.7 |
9.726 |
39.97 |
2013-10-09 |
408.4 |
10.378 |
$3.169 |
39.35 |
2013-10-15 |
383.5 |
9.858 |
38.9 |
2013-10-21 |
370.1 |
9.276 |
$3.289 |
39.9 |
2013-10-24 |
311.2 |
7.913 |
$3.289 |
39.33 |
