Old 08-09-2012, 10:51 AM   #71 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Here's my enclosure, it's a bit oversized by depth fot that case, but it's good air vent when it can't get fully closed
Maybe i'll sink it in front of the meters in distant future
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 12-04-2012, 11:17 PM   #72 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Finally got around to making something that looks like an enclosure. Used some oak strips that were left over from trimming a drawer front. Glued it together w/Gorilla glue, and put a coat of poly on it. Left one side open to help ventilation.
Old 01-08-2013, 10:08 AM   #73 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
My MPGuino setup:
Full description you'll find here:
http://ecomodder.com/forum/showthrea...tml#post349427
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following 4 Users Say Thank You to AndrzejM For This Useful Post:
2000neon (01-08-2013), Cd (02-09-2015), ECONORAM (08-13-2013), firehawk618 (04-09-2015)
Old 01-08-2013, 10:16 AM   #74 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
That looks awesome!
Old 08-07-2013, 06:06 PM   #75 (permalink)
I made another case, and this time it's better.
More images: http://mthtek.com/mpguino_enclosure.php?eng=eng
And i'm selling those also
But 'im gonna integrate the MPGuino near the speedometer at some day, like some of you have done. It is just cool
Brrrmm
Old 12-13-2013, 02:00 PM   #76 (permalink)
Here's my enclosure, it's not yet finished but this is close to final version.
Car is Toyota Carina II
ID:	14249   Click image for larger version
Old 05-03-2014, 11:02 AM   #77 (permalink)
cat2
Felar's Avatar
crabi - '93 Toyota Sprinter Carib II AE95 AV-II
Send a message via ICQ to Felar
finally, i've installed mine into ashtray space.
nobody is perfect. i am nobody.
Old 12-07-2014, 07:01 AM   #78 (permalink)
Emerald - '97 Honda Civic CXi
90 day: 40.13 mpg (US)
My MPGuino and case (100x50x25mm (external) Black ABS Plastic Enclosure if you're wondering - no affiliation with the seller).
The body of the case turned out to be slightly wider than the lid, leaving the obnoxiously shiny edge visible all around. I made a bevel with a block plane and roughed it up with some 80 grit sandpaper, which worked nicely - oh, and I waved the flame of one of those mini torch/lighters after sanding to get rid of the whitish rough look you get when sanding plastic - you have to look really close to see the difference between the moulded/patterned bevel of the lid and the planed/sanded bevel of the body (see 3rd picture). Could have just cut the display hole in the other side of the box, but then I'd have to look at the screw holes
This case is a nice snug fit - approx. 8mm to spare vertically (I mounted the board as high as it would go, for easy button access), 11mm to spare horizontally, and I had to sand the chunky screw terminals of the MTH-tek MPGuino down by about 1mm so the screen sits parallel with the lid - at least it won't be rattling around.
ID:	16563   Click image for larger version
ID:	16564   Click image for larger version
Old 02-08-2015, 04:25 PM   #79 (permalink)
AndrzejM's Avatar
My enclosure in VW Polo - with a huge display
The Following User Says Thank You to AndrzejM For This Useful Post:
Quezacotl (02-08-2015)
Old 02-09-2015, 09:24 AM   #80 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
You know you're a hypermiler when the biggest display on your dash is your MPG readout
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
AndrzejM (02-09-2015)
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
STUFF HAPPENS TV Show bennelson The Lounge 2 10-17-2008 10:05 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 06:40 PM
