Old 01-24-2009, 12:34 AM   #1 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Chevy (Daewoo) Aveo5 SV
90 day: 30.55 mpg (US)
The Enclosure Thread, Show Yours Off!!
just finished making my enclosure. i like the results. i used some click pen cap internals to make some case buttons. there is also a video showing the function of the case buttons.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 02-22-2009, 09:04 PM   #2 (permalink)
Ziggy - '95 Audi S6 Sedan
Manfred - '97 Audi A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 Audi A4 Quattro Avant
Sherman - '98 Audi A6 Quattro Avant
Cab - '96 Audi Cabriolet
Very similar to mine. For button extensions, I cut up a ballpoint pen refill, cleaned it out and reamed to fit the tactile buttons. As an added bonus, the backlight from the display shines on the button extensions so I have lighted buttons.
This is a Fundamental Logic MPGuino v1.0. Only the RJ-11 connector is brought outside the box. When I want to connect to USB, I open up the box. Pretty handy actually. Just unscrew the cover and carry the Guino with me. The display is red from SparkFun.
The Following User Says Thank You to rmccomiskie For This Useful Post:
brucepick (04-24-2010)
Old 02-23-2009, 12:43 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I like it. Looks quite professionally done.
Winter daily driver, parked most days right now
Summer daily driver
Old 02-23-2009, 03:05 PM   #4 (permalink)
looks pretty good there. is that the radioshack case your using?
Old 02-23-2009, 03:20 PM   #5 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I'm getting much inspiration for my MPGuino build. I actually have a project box sitting around that should be the right size to do the same thing as you, rmccomiskie. In fact, now I have an idea of what kind of room I have to add the LED output for my OEM wideband display in the same box.
Old 03-24-2009, 08:38 AM   #6 (permalink)
It's a Hammond Manufacturing box PN 1591 (4.5" x 2.5" x 1.1"). Picked it up at U-Do-It Electronics in Needham, MA. Mounted the way it is, the RJ11 connector just barely clears the bottom of the box in the cutout. That was just luck. I didn't plan it that way.
Old 03-24-2009, 08:40 AM   #7 (permalink)
There's a little room on the right side. If you're using the later MPGuino ver. 2 from Fundamental, both the RJ11 and the USB connectors are on the left end of the board. There should be nothing in the way on the right.
Old 03-24-2009, 11:52 AM   #8 (permalink)
That VX guy!
TomO's Avatar
I'm using the first version board, so my connectors are on opposite ends. But I should still have room to remotely install the LED array from the Wideband monitor in the same box as the Guino.
I might actually get to building it in the next two weeks. I've been busy prepping/fixing an 03 Honda Odyssey that we just bought.
Old 05-17-2009, 06:41 PM   #9 (permalink)
I recently finished installing the MPGuino display in the instrument cluster of my '96 Passat TDI.
I'm pretty happy with the results, but it was a lot of work. In order to find something small enough to fit in the dash, I used Newhaven Display NHD-02161Z-FSY-YBW-C along with Molex 0520891619 FFC adapter. It was quite the crash course in soldering tiny wires!
The miniature display compared to the MPGuino original:
The cluster I'm running is out of a VR6 Passat with an auto trans. The automatic cars used a LCD display under the tach face plate to indicate gear selection. My car is a 5-speed so I used the space in the tach face to mount the display.
I desoldered the original LCD from my Spiffie MPGuino and mounted (crudely, I might add) the board to the back of the instrument cluster. I powered the LCD backlight directly from the instrument cluster lighting through a 270 ohm resistor so the MPGuino display would dim with the rest of the gauges.
Finally, I ran a trio of pushbutton switches in parallel with the tactile switches on the board itself and mounted these under the steering wheel.
I'm fairly pleased with the results overall. The small display has a fairly large space between the top and bottom rows of text which hampers readability somewhat, but not too bad. Also, I was hoping for a better match of the LCD backlight with that of the existing gauges. But it all works as it should and it's been a fun learning experience.
The Following 3 Users Say Thank You to yetimus For This Useful Post:
ECONORAM (12-04-2012), TOOQIKK (08-29-2011), Xist (02-10-2015)
Old 05-17-2009, 07:48 PM   #10 (permalink)
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Honda Civic HX
90 day: 44.37 mpg (US)
Now that is just gangsta. Very good! My case is in the mail, I'll post up pics ASAP.
The Following User Says Thank You to LeanBurninating For This Useful Post:
EggyD (09-06-2011)
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
STUFF HAPPENS TV Show bennelson The Lounge 2 10-17-2008 10:05 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 06:40 PM
