Old 06-11-2014, 11:04 PM   #1 (permalink)
engine off and coast question
I have an 07 honda fit new to me. Since I found this site I've herd of this alot please elaborate.
How long does the engine have to be off and started back up to benefit over neutral idiling?
How viable is this technique saving gas over wearing out my electrical system. (At so can't gear start)
Old 06-11-2014, 11:22 PM   #2 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
The gains are there, they are compounded after dozens and dozens of engine off coasting , you will save a negligible amount but it will add up and you can hypermile with it to get more gains. The technique defiantly works it`s just to much work for me..
I don't engine off coast because I don`t need to to get great gas mileage , I normally coast with engine On unless its a extremely long coast , like a 5 or 10km , I have a mountain Pass that I coast home from for over 10kms a couple times a month.
Save gas
Old 06-11-2014, 11:33 PM   #3 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
5+% possibly?
Old 06-12-2014, 06:13 AM   #4 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Agressive EOC and engine off at lights gave me massive gains on my MB100, over 15%.
BMW and Ford have auto stop start systems and quote 3 and 5 seconds as the break even period. I have auto stop start on my Fiat I won't buy another new car without it.
Most people will agree that starting a hot engine takes very little power and places minimal stress on the starting system, though it may be a good idea to add a solar panel to keep the battery fresh (which is what I did).
I bump started where possible though.
Old 06-12-2014, 06:35 PM   #5 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
I just randomly did a google search for the cost of a 2007 Honda fit starter
it ranges between $50 (ebay) - $172 (remanufactured oem)
I've saved over $600 in fuel costs PER CAR / PER YEAR by hypermiling/ecomodding both my old Honda Del sol and Subaru wrx sti
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 06-12-2014, 11:45 PM   #6 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Can your vehicle be flat towed?
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 06-13-2014, 12:47 PM   #7 (permalink)
Is your Fit an automatic or manual transmission? If it's the latter, then bump starting will save your starter. I would say 5 seconds is an absolute minimum. It would get too complicated to do it more often.
I would start EOC'ing at the *best* situations, and then add shorter times as you see fit. (No pun intended!)
Old 06-13-2014, 01:07 PM   #8 (permalink)
Hydrogen > EV
He said AT.
If your vehicle can not be flat towed, I would not advise EOC.
Best Tanks:
Old 06-13-2014, 01:52 PM   #9 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.01 mpg (US)
I've been turning my engine off at stoplights in my truck for decades - literally decades. And now with the truck entering its 27th year, it's on its third starter. You might wear the starter a little faster than otherwise, but averaging nine years on one isn't bad either. And my truck's mileage is fantastic.
I would recommend shifting to neutral for coasts rather than coasting in gear. You would need to do some math to figure out where the break is, but I think the greater glide in neutral will more than offset the zero fuel use of the shorter glide with the tranny driving the engine. An engine control system will usually reduce the fuel feed to the engine in such a state to zero, but the engine drag pulls the vehicle speed down too quickly. The engine doesn't pull much gas just to idle, so the longer glide can deliver better results. Again: testing and math to know where the better results lie.
Old 06-20-2014, 10:46 AM   #10 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I've heard a break even point of 7 seconds... via this site. Make doubly sure your vehicle can be flat towed before you try this, and always do it in neutral only. Automatic transmissions are not generally made for that kind of stuff, whereas manuals have no problem (but also must be in neutral).
