Old 02-06-2012, 05:23 PM   #1 (permalink)
The Saudi Terminator
Saudi Terminator - '93 Geo Metro Base
90 day: 66.59 mpg (US)
Engine off coasting?
How long do you need to coast before you actually gain increased mpg? Engine off for more than 6 seconds? At what point does it actually cost more to start (fuel enrichment) the engine back up vs just engine on coasting?
1993 Geo Metro- 361k on original drivetrain minus head. Best mpg of 75.23. Grille block,mirror delete, kammback, fender skirts, and 135-80-15 tires..... Oh and alot of Hypermiling techniques.
Old 02-06-2012, 05:31 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
It depends on how long and how hard you used the gas pedal before you started the coast, and how long your trip is. Typically with a Scangauge or Ultra-gauge, you'll see immediate mpg gains when you start coasting, within a block or two. Get instrumentation like that, and eliminate the guesswork.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 02-11-2012, 12:24 AM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
If you bump start does it change the mixture? (Specifically Mazda F2 engine)
Old 02-11-2012, 02:18 PM   #4 (permalink)
I have heard that the engine if left off to long (eoc) then when fired back up the ECM goes into fuel enrichment ... I am not sure..just curious..
Old 02-11-2012, 06:04 PM   #5 (permalink)
Pishtaco
SentraSE-R's Avatar
Again, it depends on the ECU software. My 2002 Sentra went into open loop (enrichment) for a full 4 minutes following any EOC. My 2006 Scion stays in closed loop most of the time when restarted, even after a 5 mile EOC.
Darrell
Old 02-11-2012, 06:27 PM   #6 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
5 miles is a long coast, those are definelty worth turning the engine off, but for anything under 30 seconds i don't think it's worth turning the engine off
Old 02-11-2012, 09:35 PM   #7 (permalink)
Similar question: What's the shortest time where turning off and re-starting your engine is a net gain over idling? Or, at what time is it the same or better to idle, if any?
Old 02-11-2012, 09:49 PM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
The automotive pundits say 7 seconds is the magic number with modern fuel-injected cars. Shut your engine down at any stoplight where you'll be idling >7 seconds. You'll use less gas to restart it than you'd waste idling. The EPA says $.17 of every gas dollar is wasted idling.
Darrell
Old 02-11-2012, 09:52 PM   #9 (permalink)
Thank you. Now does that figure change with kick-starting?
Old 02-11-2012, 10:06 PM   #10 (permalink)
Pishtaco
SentraSE-R's Avatar
Probably not. The 7 second comparison is strictly fuel used. It doesn't consider electricity to crank the starter. Bump starting is more efficient than using the starter, but you may pay by replacing your clutch sooner.
Darrell
