Old 06-30-2019, 07:06 PM   #11 (permalink)
KrautBurner's Avatar
Cavalier of D00M - '05 Pontiac GTO LS2 T56
90 day: 23.2 mpg (US)
The New One - '10 Toyota Prius II
90 day: 51.55 mpg (US)
Chick Magnet - '91 Geo Metro 3cyl/5sp
90 day: 48.07 mpg (US)
Originally Posted by 2000mc View Post
While e0 is more energy dense than ethanol, I think the difference between e0 and e10 should be about 3%
In a study looking at mileage with different ethanol blends the general trend follows the energy density. That being said, your mileage will vary, The Ford Fusion tested did almost 15% better on e0 vs e10, while a flex fuel impala did just over 15% better on e20 vs e0.
http://www.speedperf6rmanc3.com/cont...evel_Study.pdf
that's my understanding, and why I'm surprised I'm seeing such a large increase
I realize that each car could act a little different as well as all the testing controls
I probably won't need fuel till this Wednesday (that will be my 3rd full tank)
so it will be a week or so before I get a reading on regular E10 again
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
Old 06-30-2019, 07:20 PM   #12 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 64.01 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
I don't really have any knowledge to back this up, but maybe older cars would react better to E0 because their ECU programming is less sophisticated, and newer cars are better programmed to handle different grade fuels?
Have you tried E0 in any of your other cars with success?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
KrautBurner (07-01-2019)
Old 07-01-2019, 12:01 AM   #13 (permalink)
I have found that older gas hogs don't care.
Gas hogs like 4.6l crown vic.
Fuel efficient cars appreciate e0 more.
Old 07-01-2019, 01:23 PM   #14 (permalink)
90 day: 42.54 mpg (US)
I tested a few tanks of E0 in my Insight and could not find any discernible difference in economy. I think the math shows it should be around 3%. I might give ethanol-free premium a try with my new engine but I'm not holding my breath.
mpg_numbers_guy (07-01-2019)
Old 07-02-2019, 01:42 PM   #15 (permalink)
if I'm doing the math right
it looks like "IF" the fuel economy stays about the same,
I'm spending $0.07 / Mile with E-0
I was getting $0.075 / mile on E-10
Old 07-02-2019, 11:59 PM   #16 (permalink)
Originally Posted by KrautBurner View Post
....I logged the first few tanks averaging about.....44mpg
then switched to NON-ETHANOL Regular (87oct)
the first tank.....got me about 49.5mpg and the 2nd tank got me 51.1mpg
this is a much larger difference than I was expecting....
I have 10+ years of experience with 87 octane 10% ethanol blend (E10) vs. 87 octane ethanol-free gasoline (E0). My 5 low-compression ratio, 87 octane gasoline engines show a percentage MPG increase, E0/E10 of 8%, 8%, 7%-8%, 7%, & 5%. E10 advocates tote the energy difference between E0 & E10 of 3% as showing only 3% MPG gain for E0 over E10. However, the following is important:
87 octane 100% gasoline component (E0) is 87 octane. duh!
Reported in many websites, inaccurate but "designated" 87 octane 10% ethanol blend (E10) has a gasoline component that is 84 octane. Because of great quantities of "ethanol in gasoline industry" propaganda & lobbying to artificially lower E10 prices, American drivers have accepted 84 octane component gasoline to be used (not efficiently burned) in their 87 octane gasoline engines. But, 87 octane E0, as burned properly in an 87 octane, low compression ratio designed gasoline engine, has 8% to 5% better MPG than inaccurate, but "designated" 87 octane 10% ethanol blend, which has neither ethanol component or gasoline component that is 87 octane.
Now the "ethanol in gasoline industry" is pushing inaccurate, but "designated" 88 octane, 15% ethanol-blend (E15). Inaccurate, but "designated" 88 octane ethanol-blend E15 has a gasoline component with an octane of 83.5.
If the "ethanol in gasoline industry" can successfully market inaccurate, but "designated" 88 octane ethanol-blend E15, they will then push inaccurate, but "designated" 87 octane ethanol-blend E15, which has its gasoline component as 82.4 octane. In all cases, the ethanol blends have no fuel components that are 87 octane & all ethanol blends are inefficiently burned.
The magic & power of propaganda to get people to accept products in their lives which are not "efficient" is remarkable.
Glad to see you live in Sequim. I live on the east side of the Salish Sea (Puget Sound). Do you buy your Ethanol-free E0 at Chimacum or Port Angeles? Sorry, you have to pay so much for E0. Its still expensive, but on the east side here, I get my E0 for $3.42.
Old 07-03-2019, 04:11 AM   #17 (permalink)
I get it at R Corner (half way between PA and Sequim)
256421 Highway 101
Port Angeles, WA 98362
United States
They also have premium
I normally get my E-10 premium at the Co-op in Sequim
216 E Washington St, Sequim, WA 98382
Old 07-09-2019, 02:39 PM   #18 (permalink)
3rd tank of E-free fuel
Ended up with 49mpg
I filled with regular E-10 to see if it drops back down
Old 07-09-2019, 02:48 PM   #19 (permalink)
Are you certain that's how it works?
To use a similar item as an analogy, you *can* in fact get the properties of a 5w30 oil by mixing a 5w20 and a 5w40. It isn't just two dissociated oils floating around in the crank case, they average out and you get the desired viscosity.
Gasoline itself is a mixture of a lot of different compounds anyway.
Taken from Wikipedia:
The octane rating of gasoline is measured in a test engine and is defined by comparison with the mixture of 2,2,4-trimethylpentane (iso-octane) and heptane that would have the same anti-knocking capacity as the fuel under test: the percentage, by volume, of 2,2,4-trimethylpentane in that mixture is the octane number of the fuel. For example, gasoline with the same knocking characteristics as a mixture of 90% iso-octane and 10% heptane would have an octane rating of 90. A rating of 90 does not mean that the gasoline contains just iso-octane and heptane in these proportions but that it has the same detonation resistance properties (generally, gasoline sold for common use never consists solely of iso-octane and heptane; it is a mixture of many hydrocarbons and often other additives). Because some fuels are more knock-resistant than pure iso-octane, the definition has been extended to allow for octane numbers greater than 100.
Octane ratings are not indicators of the energy content of fuels. (See Effects below and Heat of combustion). They are only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. Where the octane number is raised by blending in ethanol, energy content per volume is reduced. Ethanol BTUs can be compared with gasoline BTUs in heat of combustion tables.
It is possible for a fuel to have a Research Octane Number (RON) more than 100, because iso-octane is not the most knock-resistant substance available. Racing fuels, avgas, LPG and alcohol fuels such as methanol may have octane ratings of 110 or significantly higher. Typical "octane booster" gasoline additives include MTBE, ETBE, isooctane and toluene. Lead in the form of tetraethyllead was once a common additive, but its use for fuels for road vehicles has been progressively phased-out worldwide, beginning in the 1970s
Old 07-09-2019, 06:15 PM   #20 (permalink)
over 4 tanks of regular E-10 I was averaging about 44.5mpg
after 3 tanks of E-0 my average is 49.9mpg
3-tank Fuel Economy: 49.9 mpg (US), 4.7 L/100 km, 59.9 mpg (Imp)
EPA Combined Rating / % over rating: 40 mpg (US) / 16.4% (based on 90-day fuel economy)
The Following 2 Users Say Thank You to KrautBurner For This Useful Post:
Ecky (07-09-2019), TexasCotton (07-10-2019)
