Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-21-2012, 11:30 PM   #51 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
no i am not clueless -
you are attempting to perpetrate a hoax ,
i do not yet know why
but you are going to have a wee bit of trouble foisting your blarney here .
so far you are UNable to respond to my posted facts with any kind of debate
so
post something from your vast storehouse of knowledge to refute what i have posted .
absent that .
my facts stand .
and you will have proven yourself and your hoax to be a fraud
by default .
ready
begin
i eagerly await your reply .
Originally Posted by ramman360 View Post
I wish people would read. A I have a touch screen smartphone. Second if you have a question call me cause its quicker if you can be nice my number is 765 465 8065 early morning or later afternoon because you guys are clueless too what iv done and am doing.
The Following User Says Thank You to mwebb For This Useful Post:
mcrews (05-21-2012)
Old 05-22-2012, 12:40 AM   #52 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
think it says banned under his name for a while now
Old 05-22-2012, 12:41 AM   #53 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by mcrews View Post
What I find so interesting is how unique each one is!
Maybe what happens is that these ideas are so out there, they actually go full circle, ending up on the useful side. It's probably how hybrids, diesels, LRR tires and Scangauges were ALL invented!
Old 05-22-2012, 08:08 AM   #54 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Tomorrow we'll probably see ramman361.
Transmission type Efficiency
Old 05-22-2012, 08:11 AM   #55 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
what if it was supposed to be RAMON and he just couldn't spell!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-22-2012, 11:22 AM   #56 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Or maybe he likes top RAMEN?
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
Old 05-25-2012, 05:22 PM   #57 (permalink)
It's up to me how I spell my name. The scientific method and peer review are alive and well at ecomodder.com even if civility is some times in short supply. Every bit of data is useful for attempting to repeat a result. I have had leaks in my fuel evaporation system tubing that caused a "Check Eng" light to come on. I did not track mpg at that time but the vehicle did not seem to run differently. The vehicle is a 2002 Dodge Gran Caravan 3.3L with EFI and AT. Depending on the routing, a missing vacuum line may cause a lean condition. The fuel in the evaporation capture system could be lost to the atmosphere. Best to look at the vacuum line diagram under the hood or in the repair manual. The overall goal is to use the heat value in the fuel to maximum efficiency.
Take time to review basic principles of chemistry, fluid mechanics, and thermodynamics. This will help put testing on a solid basis and minimize urban myths. It least we will have a way to understand how a modification might work.
Old 05-25-2012, 08:18 PM   #58 (permalink)
mcrews's Avatar
Originally Posted by Grant-53 View Post
It's up to me how I spell my name. .
I.m sorry.......who are you and why are you making that comment on a thread you haven"t posted on...that has run for 6 pages.
I am so confused
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-26-2012, 01:50 AM   #59 (permalink)
mwebb's Avatar
not true
that is not true
a missing vacuum line on a speed density system such as your s will NOT cause lean condition
Mr MAP sensor cares not if there is un metered air . as Mr MAP sensor only looks at
Manifold Absolute Pressure which is UN affected by even large vacuum leaks that may be present in EVAP lines
Mr 02 sensor will maintain stoich even if a purge valve or LDP is stuck open drawing extra HC into the intake .
just to civilly set things straight
very little can cause lean or rich condition when fuel trim has such a wide range of correction available as your system has
Old 05-26-2012, 06:23 PM   #60 (permalink)
Sorry for the confusion. Messing with a person's name is such a seventh grade thing. The Unicorn Corral so often gets into the area of the Conspiracy Theory mindset. It is hard sometimes to be patient even for those of us with customer service experience.
I am not clear on the year and model of the throttle body system under discussion by Ramman360, so I used a general approach. My current vehicle is likely different than older TBI systems which evolved over a period of years. My 1971 Torino 6cyl was undriveable because of a vacuum leak that would not bother a modern car. Since the van is my wife's car I might ask you to refer to Mrs. MAP sensor.
