06-14-2014, 04:05 AM
#61 (permalink)
I found a unicorn...........
06-14-2014, 07:49 AM
#62 (permalink)
What's its stock application?
06-14-2014, 11:13 AM
#63 (permalink)
The manic mechanic
Hondo - '03 Hyundai accent gl 90 day: 33.81 mpg (US)
Where did you find this and where can we get more information?
06-14-2014, 12:04 PM
#64 (permalink)
In Lean Burn Mode
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
06-14-2014, 12:11 PM
#65 (permalink)
I never thought it was pure unicorn.
That thing looks astronomically expensive and we already know the benefits of a belt driven alt delete.
Put those 2 together and I dont think you will come out ahead.
06-14-2014, 12:17 PM
#66 (permalink)
Not to get off topic, but doesn't KERS store energy in a flywheel? Looking at the diagrams, ERS looks more like a battery... I wasn't aware of any batteries that could handle that extreme charge/discharge rate. Is it a battery, or still a flywheel?
06-14-2014, 12:34 PM
#67 (permalink)
In Lean Burn Mode
Here's the new style F1 flow chart.
The KERS is no longer used and has been replaced by the new MGUK.
06-14-2014, 12:40 PM
#68 (permalink)
In Lean Burn Mode
Here's another car using a turbine recovery system.
The Porsche 919 Hybrid.
This unit is a GUH Generator Unit Heat, not like the MGUH Motor Generator Unit Heat F1 uses now.
06-14-2014, 12:42 PM
#69 (permalink)
Interesting. A little more digging shows a battery of 35 kg (77 lbs). I wonder what battery chemistry they're using...
06-14-2014, 01:31 PM
#70 (permalink)
In Lean Burn Mode
From my understanding they're using lithium-ion cells. There's not a whole lot of information about them though? lol
