Old 08-26-2020, 06:28 PM   #941 (permalink)
It appears to have a Type III engine, but I suspect the transaxle has bee raised to keep the back low with those tall rear tires.
I don't remember how some lowered Beetles in Brazil don't get an extremely negative camber, but it often doesn't involve raising the powertrain. Not totally unheard of lowered cars with the powertrain entirely raised, so maybe it could be the case on this one.
Old 08-26-2020, 07:01 PM   #942 (permalink)
It's popular in the high-end drag racing scene. In the 1950s, instead of raising the transaxle they'd put Type II portal axles on upside down. (Hint: the lubrication doesn't work)
"We're deeply sorry." -- Pfizer
Old 09-07-2020, 08:40 PM   #943 (permalink)
Chopstix should like this one.
The only OEM parts are the windshield wipers, but it can get 50mpg.
I like the NACA ducts for rear brake cooling. With a stock engine that could be enough to feed the engine plenum.
Old 09-17-2020, 05:53 PM   #944 (permalink)
http://forums.pelicanparts.com/off-t...l#post11015513
One suspects it's bark is worse than it's bite. OTOH, it's interesting the way the voltage regulator [?] is mounted on the generator, and neatly wired in.
Old 09-22-2020, 06:23 PM   #945 (permalink)
Primer is still paint!
ChopStix's Avatar
The Following User Says Thank You to ChopStix For This Useful Post:
skyking (09-23-2020)
Old 09-22-2020, 07:27 PM   #946 (permalink)
Clicking the bar doesn't make it bigger.
IIRC, not a sunroof opening. What it needs is a lift-off padded Carson top. Or a plexiglass bubble slump-molded over a regular roof.
Old 09-28-2020, 03:02 PM   #947 (permalink)
https://justacarguy.blogspot.com/202...dnt-stock.html
Note the little brushes to clear the rails.
Old 09-30-2020, 01:18 AM   #948 (permalink)
Old 09-30-2020, 03:16 AM   #949 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Found this guy hiding out in the woods:
Old 10-01-2020, 01:33 PM   #950 (permalink)
I don’t know if this one was posted yet.
https://www.instagram.com/p/CFjA0wFg..._web_copy_link
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
