Old 07-12-2008, 08:00 PM   #31 (permalink)
adrive7's Avatar
Ranger - '08 Ford Ranger XL
90 day: 20.73 mpg (US)
Send a message via AIM to adrive7
For Reynolds number use 2,500,000. At car speeds, and since this is air, the Reynolds number is always going to be around this for what we are interested in. dt is the time step of the movie, so keep it small. Gravity doesn't play into this simulation, so your top down view will work fine (you just wont see the effect of the air moving under and over the vehicle.
Ohio State Baja SAE
Old 07-13-2008, 02:02 AM   #32 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
adrive7: Thanks, the VLC program worked like a charm.
here's a few vids of old Harold in action.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 07-14-2008, 12:02 AM   #33 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by cfg83 View Post
Chris -
I processed yours and put it on YouTube :
I made the Taco smaller and put a road underneath.
I'll delete it from YouTube if you want me to.
CarloSW2
right on, thanks..
how did you get it to work? I wasn't clear on the settings..
can you send it to me? PentastarTurbo@aol.com
for the record, VLC didn't play it for me already had it..
Old 07-14-2008, 12:36 AM   #34 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Chris D -
The only value I changed was the time. I changed it to 40 seconds. Now I think the YouTube is wrong because, according to adrive7, the Re needs to be 2,500,000.
Originally Posted by Chris D. View Post
right on, thanks..
I will do the same analysis with an Re of 2500000 and send you an e-mail.
CarloSW2
American Solar Energy Society
Old 07-14-2008, 12:44 AM   #35 (permalink)
Peakster's Avatar
Red Jeep Patriot - '07 Jeep Patriot
90 day: 25.14 mpg (US)
Beige Ford Ranger - '95 Ford Ranger XLE
This is just too much fun!!! Totally found my new favorite toy .
Old 07-14-2008, 02:06 AM   #36 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
co_driver -
Originally Posted by co_driver View Post
Numbers to use:
L* = effective diameter of your car [1990 Firebird: (72.4" (width) * 49.8" (height) )^0.5 = ~60" = 1.53 m]
v = velocity [50 mph = 22.35 m/s]
'nu' = 1.6*10^-5 m^2/s
Thus: Re = 1.53 * 22.35 / 1.6*10^-5 = ~2,100,000
(*) Note:
A better reference would be the effective diameter rather than its length, as length is used for flat plates.
Now, on to making 2-D renditions of vehicles I have once owned...
I'll plug my SW2 numbers in :
L* = effective diameter of my car
[1999 Saturn SW2: (66.7" (width) * 54.5" (height) )^0.5 = ~60.29" => 1.53 m]
======> Same as Firebird Example, so the rest of my numbers will be the same.
v50 = velocity [50 mph = 22.35 m/s]
v55 = velocity [55 mph = 24.59 m/s]
v60 = velocity [60 mph = 26.82 m/s]
v65 = velocity [65 mph = 29.06 m/s]
Thus: Re50 = 1.53 * 22.35 / 1.6*10^-5 = ~2,140,000
Thus: Re55 = 1.53 * 24.59 / 1.6*10^-5 = ~2,350,000
Thus: Re60 = 1.53 * 26.82 / 1.6*10^-5 = ~2,560,000
Thus: Re65 = 1.53 * 29.06 / 1.6*10^-5 = ~2,780,000
I've been using 2,500,000 for my second run, so that means I've been calculating for a little under 60 MPH.
Based on the above, I have attached a super-simple Reynolds Number calculator using Microsoft Excel. Enjoy!
CarloSW2
Old 07-14-2008, 04:08 AM   #37 (permalink)
Peakster's Avatar
You know I was just curious :
Old 07-14-2008, 11:09 AM   #38 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
I'm getting some interesting movies using the high Re numbers.
I get a lot of this:
using 2,500,000. Is it supposed to look like that?
Old 07-14-2008, 11:10 AM   #39 (permalink)
EcoModding Minded
Chris D.'s Avatar
2000 era mustang, cool
mite have some slight color differences on the background causing the turbulence..
mite have to go over the whole background in one color, try that and repost it..
Old 07-14-2008, 11:15 AM   #40 (permalink)
Ex-lurker
Here's the source image:
2 bit, no antialiasing. I'll try bumping it up to 8 bit.
*EDIT*
Here's the video on 8 bit. (haven't figured out the embedding thing yet)
http://www.youtube.com/v/7w_nCKP-co4
air dam, air flow, simulation, spoiler, wind tunnel
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
