Old 07-22-2019, 07:40 PM   #11 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by M_a_t_t View Post
How much hp and torque does an a/c clutch hold up to? Maybe you could go electro-magnetic clutch on the rear wheel to retain engine braking?
Going electro magnet would mean you need electricity to keep it engaged. Not good for MPG. Of course, if you can reverse it, then you only need electricity to coast.
Originally Posted by Spaghetti Man View Post
In that case I'd have to install a clutch on an NBC110 which has a centrifugal clutch.
I wonder if the grom engine would fit...
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 07-22-2019, 11:36 PM   #12 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
A/c clutch is the most common. There is probably normally engaged clutches for some other application right? It would be interesting regardless.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 07-29-2019, 09:46 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
fwiw, the ac clutch coil is like 2 to 5 ohms, like a 50 watt load. might not be a big deal if it solves more problems than it creates.
scanning this, it looks like you can expect very roughly about 80 foot/lbs from an automotive ac clutch.
https://www.warnerelectric.com/-/med...p-1091-we.ashx
in perspective, you could put one on the output shaft of a ninja 250, and if you never used first gear you might get away with it.
they make larger magnetic clutches though, in some AWD, or a larger vehicle in need of AC.
Old 07-30-2019, 12:03 AM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
edit: I think probably the "grind the detent cam" so you have a half click neutral between all the gears approach would be a lot easier to implement, if you know where/how to grind.
keep in mind that most motorcycle trannys aren't properly lubricated for lots of miles unless the engine is running (or you have made other provisions).
