02-28-2012, 09:43 PM
#11 (permalink)
I'll attempt it again later, I tried before and it wouldn't resize. That is lawn edging across the bottom, and man the car handles better now. I just have to be careful as the front end tends to scrape on tall speed bumps, driveway lips, etc. I did notice I am more stable in the rain than without the lip on. Next step is to test the side skirts, more lawn edging, and rear wheel skirts.
02-28-2012, 10:59 PM
#12 (permalink)
Cyborg ECU
These pics are great. Are you going to duct air directly through the radiator? You can use black plumbing pipe insulation, wedging it into the cravices, securing it with zip ties at key spots.
Originally Posted by Reloadwin
What did you use for the bottom front lip?
He's using black lawn edging, same stuff I used, and I got the idea from Frank Lee and others on here... but they got it out of that great well spring of useful knowledge sometimes known as "redneck engineering". Awesome.
02-29-2012, 03:54 AM
#13 (permalink)
I swapped out grills a couple of months ago, and the only spot for air to enter the engine bay now is a slit about an inch tall above the front bumper. It goes right through the radiator and keeps the engine plenty cool, no ducting needed. I love the spoiler so far, and it was absolutely worth the investment.
02-29-2012, 10:27 AM
#14 (permalink)
Cyborg ECU
Watch your running temps as the days get warmer in North Carolina this spring. You might want to open a small area in your current grill block and duct it and the 1 inch crevice in your upper grill, so that no air can go around the radiator, but rather all has to go through it. It helps in the warmer seasons.
02-29-2012, 09:30 PM
#15 (permalink)
Thanks for the advice, my truck was horribly prone to overheating in the summer time. I have toyed with making an adjustable vent that goes to a lawn mower throttle mounted on my center column. This would enable me to open up for more air if the car starts running hot.
03-01-2012, 04:18 AM
#16 (permalink)
Holy cow...that thing looks like a lifted 4x4! I'd do something about that wheel to fender gap!
03-01-2012, 05:40 AM
#17 (permalink)
I wish we could buy shaped lawn-edging like that here in the UK! Makes a really nice looking job of it.
All I can find is 1mm thick flat stuff...
03-01-2012, 11:37 AM
#18 (permalink)
SoCal, I am working on finding a combination tire upsize, suspension lowering that will fit and be affordable enough to justify. I have debated a partial front wheel skirt, but that is just a mental though right now. Those Sentra's have dang good wheel travel off road btw.
Kingsway, you may be able to order that kind of edging online, if you are willing to pay for shipping. It is less than $6 in my part of the country.
Today is a warm day, so I will see how the bumper effects engine temps. Hopefully I don't need to rig up a vent.
03-01-2012, 07:39 PM
#19 (permalink)
The cost of shipping from the US is pretty scary... I paid nearly double for an Ultraguage when you add shipping and customs duty
03-01-2012, 09:33 PM
#20 (permalink)
It's been a long time since I have been over your way, I completely forgot about the customs duty. Have you tried to look for some rubber seal for the bottom of a garage door. I had a friend of mine use that for his car. He had to reinforce it, but it is still holding up.
