11-23-2015, 10:22 AM
front scoops on aventador and others
ok so u know those big black air scoops on the front of the aventador, what are they for?
the engine including radiators are in the back so could they possibly be scooping air for? if they arent scooping air then what are they doing?
this is a link to an aventador from google images
i can understand the side scoops behind the doors channeling air in to the engine bay but what possible use could there be for scooping it at the front?!?
thanks
11-23-2015, 10:49 AM
Looks, aesthetics, aggressive stance, etc.
11-23-2015, 11:51 AM
Rat Racer
Looks.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
11-23-2015, 11:56 AM
Eco-ventor
Brake cooling.
The Following 2 Users Say Thank You to jakobnev For This Useful Post:
Brake cooling?
11-23-2015, 11:57 AM
Timing is everything! LOL
11-23-2015, 02:57 PM
aero guerrilla
So the driver and passenger can stretch their legs out?
The Following User Says Thank You to Piwoslaw For This Useful Post:
11-23-2015, 03:22 PM
Rat Racer
Flintstones braking ducts.
The Following User Says Thank You to Fat Charlie For This Useful Post:
11-23-2015, 04:07 PM
#9 (permalink)
Moderator
Lamborghini Aventador: the design - Car Body Design
"In the front end we find a trademark design element: the double air openings which provide cool air to the brakes.
The other cold air intake is connected to the power steering radiator."
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
11-23-2015, 05:14 PM
#10 (permalink)
front ducts
The new Hurac'a'n does the same thing.
It is an all wheel drive,so some of the air may be for front differential cooling as well.
The new Corvette uses a single inlet duct,then directs the air internally with ducting for the forebody bits.
At Cd 0.29 vs Cd 0.36 for the Lambo.,it's a lot better engineering.(maybe not quite as sexy)
