05-06-2013, 03:19 PM
#11 (permalink)
Eco-ventor
I would really like to go out and spend money on a scangauge and another throttle body but I don't have any extra.
This is were i start getting a bad vibe.
05-06-2013, 03:28 PM
#12 (permalink)
Smeghead
A scan gauge or similar will NOT provide usable data.
It derives it's fuel consumption data from air flow. The premise of this mod is that it is doing things with airflow which means data that the scan gauge/ultra gauge or similar is suspect. Something that monitors the quantity of fuel injected directly is the only data source that is even close to reliable. That means graduated cylinder (both feed and return), super accurate fuel flow gauges comparing feed and return, or an MPguino or similar that measures fuel injector pulse width and frequency.
edited to add
There is WAYtoo much variation in tank to tank data for it to be valid. I have gone from 25-28 mpg just in the last couple months. Had I put some sort of mod on the car I could easily attribute that change to the mod when it is environmental. In tank to tank comparisons driver technique has a huge role to play. Did it rain slightly more this tank than last, was it cooler, did I get stuck in traffic, did I happen to hit a lucky bunch of green lights, etc all would invalidate a tanks usability as data.
I laid out a test in This post that could provide usable data without using a rolling road.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following 3 Users Say Thank You to bestclimb For This Useful Post:
#13 (permalink)
You can try to use ultragauge (it's cheaper than SGII) or you can go for MPGuino - I'm sure you can build one with ~20$ budget. Maybe it won't be pretty but it will do its job.
Anyway good luck with testing!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
05-06-2013, 03:46 PM
#14 (permalink)
Originally Posted by bestclimb
I don't think a scan gauge or similar will provide usable data. It derives it's fuel consumption data from air flow. If this mod is doing anything the data that the scan gauge or similar is suspect. Something that monitors the quantity of fuel injected directly is the only data source that is even close to reliable. That means graduated cylinder (both feed and return), super accurate fuel flow gauges comparing feed and return, or an MPguino or similar that measures fuel injector pulse width and frequency.
Alright, here is where you are starting to talk over my head, not because I can't understand but because I haven't learned it and the "why" of it yet. So, you are saying that a scangauge measures the same way the computer in the call measures therefore it's just as inaccurate so...what's the point, right? I'm guessing that an MPGuino is a home built system using an Arduino board? I'm liking this idea....seriously! That said, can my 2005 know and monitor the fuel flow feed and return or do I need to then splice the fuel lines and install a flow sensor?
Thanks for the props, I'm all ears with this one! I really am... Any DIY hacks that I need to be aware of? I have a laptop!
Guys, I'm kinda rushing into it, I understand your skepticism. I'm a VERY methodical thinker and I REALLY, REALLY want to run these test before I modify. I want to do this the right way but I'm telling you, it's going to be two months until I can even think of buying anything more than $20 to test with so...I've got to think of my options. Why can't I monitor the fuel consumption along side of mileage on a large round trip route through the country and do this 3 times, then modify and do it all over again?
Or go ahead and modify and get an idea if it even seems viable based on my fuel usage and regular driving. Then, if it shows some improvements, go out and get that throttle body (will need it anyway either way) and locate the best testing equipment in the mean time and do some very calculated runs to come up with hard numbers in the rears? I know that this is ass backwards but I can't afford all the pretty toys today.
Thoughts?
Wayne, SC
05-06-2013, 03:47 PM
#15 (permalink)
bestclimb,
thanks for your input!
This goes back to my early post in the original thread about how smart ecomodders are!!
05-06-2013, 03:54 PM
#16 (permalink)
Wayne - can you point us to any other fuel economy testing that you've done?
05-06-2013, 04:04 PM
#17 (permalink)
Originally Posted by mcrews
bestclimb,
I agree, thank you all and bestclimb for you input! I see where you are coming from and can agree that you are right on (thanks for the edit).
I have NOT done any other economy testing, no rolling tests or anything like that on this car. Frankly, I've never done it at all...I will and can though. Like I said above, I'm a very methodical person and I will make sure that when I do the testing, it's done right with a reduced amount of variables as possible.
I gotta start somewhere and since I already jumped off the cliff and bought this thing...I'm going to go ahead and run with what I have.
You guys are making me feel bad for not having more equipment! JK
Wayne, SC
05-06-2013, 04:20 PM
#18 (permalink)
Smeghead
The scan gauge, ultra gauge and the like (I have an ultra gauge and like it for what it is) get air flow (and other) data from the car's computer from the diagnostic port. Run it though some math and spit out a fuel consumption number. When calibrated they can be pretty accurate but that calibration is only valid for that specific engine configuration.
I would say that a Scan/Ultra gauge would be good enough to test non engine related mods.
The MPguino is an arduino project that splices to the car's speed sensor and fuel injector signal wires.
Fuel injectors are either on or off. rate of flow x time the injector is on gives you the quantity of fuel injected.
It does not matter what sensors are telling the computer what, the MPguino just counts how much time the injectors are injecting.
Having used both ultra gauge and MPguino. I find the Ultra Gauge more useful for all sorts of car data and for eco driving it's inaccuracy is acceptable. The MPguino gives less information but the data it gives can be more accurate.
Can you insure that you will take every corner exactly the same, apply the exact same amount of brake, and do it in exactly the same amount of time, with the same average, max, minimum speeds, with exactly the same amount of acceleration and verify that environmental factors have not effected you data?
05-06-2013, 08:55 PM
#19 (permalink)
AB testing has terrible potential for errors. See my sig line for summer and winter average mileage in my truck, and this thread for where those numbers came from: http://ecomodder.com/forum/showthrea...yon-17070.html
I regularly make a 60 mile trip. My MPG for that particular trip ranges from 30 to over 42, depending on wind and temperature. I can get even lower mileage in a good snowstorm.
Look at my fuel log. You can easily see the seasonal variation and the tank to tank variation. For example, yesterday's fill was lower than normal for the range of temperatures because most of the miles (almost 90%) were against a headwind, while the previous fill had slightly warmer temperatures and no wind.
Yesterday's fill: Average temperature about 40 degrees and 31.6 MPG.
Previous fill: Average temperature about 65 degrees and 35.2 MPG.
A Scangauge or Ultragauge is useful for short tests on a straight stretch of road where you can test a change ABABAB several times before the temperature and wind change. Tank averages tell what happens in the real world, but it is difficult to control the variables well enough to truly measure the results of a change. I discuss this somewhat in my mod thread linked above.
Don't give up and please keep us updated.
05-06-2013, 09:40 PM
#20 (permalink)
herp derp Apprentice
2005 Throttle Body Ford Taurus 3.0L,OHV,SE $25 L and L Auto Parts, Inc. USA-NC(Grover) 1-704-487-7401 / 1-800-289-5474
Found with car-part
The Following User Says Thank You to 2000mc For This Useful Post:
