Old 08-01-2009, 06:12 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Gen 1 Insight annoyances
I'm mainly whining here, but I was really hoping the insight would have a double-wishbone suspension so I could go ahead and try to swap the insight front knuckles onto my CRX, but o no, gotta use macpherson-crap struts.
O well! Guess I'll have to whip up some custom axles.
Old 08-01-2009, 07:02 PM   #2 (permalink)
I guess I don't know what to do about it.
Old 08-02-2009, 03:09 AM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Have you considered pressing the two parts of the hub apart and checking to see if the bearing/spindle of the Insight would fit in the race of the CRX?
If it's too big, it might be better off to just take it to a machine shop and tell them to match the profile of the CRX's spindle, so you can just press it in and be done, still using the Insight axle.
Although, if the axles are the same length or really close, you may just be able to swap the ends from one axle to the other, if the splines on the shaft are correct for the "other" CV end.
Old 08-02-2009, 03:26 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yes, I've been trying to investigate those things but I can't find any information on the axles of the insight and those of the CRX in terms of spline count and length, etc. I know the CRX info is out there since I've seen it before, but no luck with the Insight.
Will pick up a shop manual soon, but waiting to get the right year.
Old 08-02-2009, 11:36 AM   #5 (permalink)
Silly me, I had presumed that you already had the parts, or at least had current access to them.
Old 08-02-2009, 12:27 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Nope, I'm trying to plan ahead before I just go and take apart my car and think "O hey, this doesn't fit right"
Old 08-02-2009, 12:36 PM   #7 (permalink)
I dunno if the HF axle's center section is any different, but I'll take it apart and count the splines for you, since it's just a junk axle anyway. Who knows, while I have it apart, I might find a use for it!
Old 08-02-2009, 01:03 PM   #8 (permalink)
Err... Maybe you need to back up a bit and try to explain why on earth you would want to do such a thing. Is it that you just need a challenge to add some interest to a boring and empty life?
Old 08-02-2009, 01:07 PM   #9 (permalink)
Dartmouth 2010
SVOboy's Avatar
That's a thinly veiled insult, there.
Anyway, the reason is because I'll be doing an insight swap and having custom axles made would be more expensive than reusing available parts.
Old 08-02-2009, 01:07 PM   #10 (permalink)
There's another thread explaining why SVO wants to add Insight guts to his CRX, rather than just getting an Insight... not sure where it is, though I'm sure I've read it.
My life is fairly boring, so yeah, I'll count the center section's splines for something to do, and to *hopefully* aid a fellow Ecomodder's pursuit of project fruition.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
What would you do to all-out modify (ecomod) a Honda Insight (gen 1)? MetroMPG Hybrids 25 11-26-2009 12:00 AM
News: Honda feeling pressure from Prius 3, planning to improve MPG of 2nd gen Insight MetroMPG Hybrids 14 07-31-2009 09:38 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Honda Insight gen 2 debut at paris auto show Daox General Efficiency Discussion 5 10-03-2008 11:00 PM
