Old 05-26-2013, 09:22 PM   #1 (permalink)
90 day: 29.44 mpg (US)
Good news everyone! I made a grill block!
Edit: I barely drove two miles and was not yet on the freeway when my Ultragauge began warning me of overheating, so I removed this and decided to try again later. Unfortunately, I had already given up when I realized that the Ultragauge itself was overheating, not my car, although my engine must have been warm if I turned on the heater--the Ultragauge was right in front of a vent. Also, it seemed impossible to shrink the plastic without creating holes. Despite having most of the plastic left, I have never wanted to attempt this again because even Ecomodders were ridiculing me.
Original post:
This was an abject failure. It was It was 89°F and 81°F when I did my "A" drives on a 51.3-mile route, 46.1 miles on the freeway and 92°F when I finished the grill block and attempted the "B" drive, but my car started overheating before I got on the freeway. I tried again at sunrise, when it was 66°F, but my engine reached 219°F and I got 31 MPG compared to 31.4-31.5 for my "B" runs, with a cooler engine.
The idea was that the plastic would be less noticeable and I chose the aluminum tape because I thought that it would withstand my heat ray better, but it certainly is visible, especially with the pieces covering the random holes.
I do not know if it is possible to shrink the plastic tight without creating holes. I do not plan on using this material again.
I did my baseline run just after 1pm. I live 2.6 miles from the freeway entrance and I chose a loop that allowed me to stay on the freeway as long as possible.
A: 89°F
Precipitation: 0%
Humidity: 7%
Wind: 4 mph [according to Google, not everything can be deduced]
I put my Ultragauge on page four so that I could see my engine temperatures. They stayed between 192 and 199°F as I accelerated to seventy and coasted to fifty. Curiously, the engine cooled seven degrees as I accelerated and then warmed back up as I coasted. Note: Eighty-nine outside, no functioning air conditioning, so I was sweating. I probably should have used ear plugs and rolled down the windows, but I would not have gotten:
31.5 MPG (Not fully calibrated).
B: 92°F
Precipitation: 0%
Humidity: 6%
Wind: 2 mph
My Ultragauge started screaming before I got on the freeway, so I slowly drove home.
So much for the hope that my car would be so aerodynamic that it would run cooler.
Hopes are not always rational.
I had planned on installing a fan indicator. As we discussed elsewhere, run wires from the fan fuse through the firewall to an LED where I could see it. Would I need to do anything special? Someone wrote that you always wanted to put... something... (a fuse?) ...whenever you added wiring, and they talked about speaker systems.
I did not figure out the details beforehand, so I decided to do it later.
ID:	13091   Click image for larger version
ID:	13092   Click image for larger version
The Following 3 Users Say Thank You to Xist For This Useful Post:
aerohead (03-26-2016), Fat Charlie (11-06-2014), MetroMPG (05-27-2013)
Old 05-26-2013, 10:34 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
very clean!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-27-2013, 01:22 PM   #3 (permalink)
Second attempt:
Tempe, AZ
Monday 7:00 AM
Mostly Cloudy
71°F
Precipitation: 0%
Humidity: 18%
Wind: 0 mph
Everything was warmer than my "A" run yesterday as I approached the freeway, cool enough for me to make the attempt, but warm enough that I turned on my heater, having forgotten two very basic details:
UG°F refers to the temperature of my Ultragauge device, and my vent blows directly on it!
I will probably try again later, once I purchase more foil tape. If I leave out the grill block, I should be able to drive when it is around the same temperature that it was yesterday, but if I actually drive at 5am tomorrow, I should be able to drive with the full block.
I hope that I did not damage the plastic too much.
Old 05-27-2013, 04:12 PM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
As a bonus it also protects your car from chlamydia!
Old 05-27-2013, 05:25 PM   #5 (permalink)
Allegedly, that is the name of a woman, and I would not even know where to begin explaining how overcome with concern I have always not been about my car getting Chlamydia.
Old 05-27-2013, 08:00 PM   #6 (permalink)
Interesting experiment, also known as the car condom.
I love foil tape.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 05-27-2013, 08:11 PM   #7 (permalink)
I sure would have saved myself some time had I known this would be the result.
Old 05-27-2013, 08:26 PM   #8 (permalink)
...beats walking...
I love foil tape.
When you walk up to your vehicle, do you mentally ask the question: "...do you know where your car has been and what it was doing?" (wink,wink)
Old 05-27-2013, 10:06 PM   #9 (permalink)
So, do you guys think that the all-in-one upper- and lower-grill block, fog lamp cover, and gap seal will work? Do you think that my engine will be able to keep itself cool at sunrise, or will I need to remove that section? Do you have any suggestions? Have any of you tried blocking this much at once?
Old 05-27-2013, 10:25 PM   #10 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
It's a unique (!) approach, but in summer temps, a 100% block is too much. You'll need to open it up some.
