Old 05-10-2012, 04:56 PM   #11 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Originally Posted by chrisgerman1983 View Post
What do you plan to use to open the shutters? The most basic would be a hood popping cable... or maybe a bike gear shifter that way each "gear" would be a different level of flow. having control over how much the shutters open would allow you to keep a perfect balance between cooling and aero
I have a donated headlight motor assembly with limit switches, and will use a simple Throttle Position Sensor (TPS) to give me the current setting. It reads 0~5 volts.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 05-10-2012, 11:54 PM   #12 (permalink)
chrisgerman1983 - '96 chevrolet astro
90 day: 14.02 mpg (US)
I look forward to seeing your setup!
