Old 09-28-2018, 04:29 PM   #11 (permalink)
SmoothLoafers
The White Stallion - '04 Pontiac Sunfire Base
Team Pontiac
90 day: 37.04 mpg (US)
Originally Posted by 19bonestock88 View Post
I知 in 5th as soon as 25mph
Cool thanks for the tips! 5th at 25mph!! What mpg do you get while cruising at that?
Also, I'm just going to let my signals blink fast. It's annoying, but only for a few seconds at a time.
Old 09-30-2018, 07:04 PM   #12 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I *think* that my UltraGauge reports something in the neighborhood of 40mpg instant at 25 in 5th... this shows as like 1000 RPM with a 195/60-15 tire... since my tires are 5% oversize (205/65) I知 actually going maybe 27mph... additionally, I値l use 4th in a school zone at like 850, but literally just barely enough throttle to maintain speed, no extra load at such a low engine speed...
And I also deal with the hyper flash since I replaced my DRL/signal bulbs with LED... no flasher delay to change out and I知 not adding a resistor to the circuit...
My current Ecotec project...
My last Ecotec project...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
SmoothLoafers (11-16-2018)
Old 11-16-2018, 03:06 PM   #13 (permalink)
SmoothLoafers
Team Pontiac
I've been cruising at lower speeds every since you told me about it. My next mod will be fog light/grill hole fill. Maybe with Lexan, but im not sure yet
Old 11-17-2018, 11:50 PM   #14 (permalink)
Team Saturn
Not than lexan wouldn't look nice, but I usually use tape of some sort for filling holes/blocking the grille... Of course the tape doesn't cost me anything, but still...
Old 03-24-2019, 05:17 PM   #15 (permalink)
SmoothLoafers
Team Pontiac
Hi all just wanted to give the final update on this. I ended up trying it all. LED Flasher, LED blinkers just front, LED blinkers just back, both, and some other things.
TLDR: I think my car and LEDS are just not compatible
The Flasher (Relay) would work perfect, or BUZZZZ at every blink. Other times it would give me an error signal <-- --> The same brand lights were used in my interior light and trunk light. The trunk light is fine, but the interior light is going bad so maybe they're not the best quality. Anyhow, I think I'm just going to keep it kosher on the lights and work on other mods. Knowing all my lights are working properly is relieving! Comfort is key.
Old 03-24-2019, 10:23 PM   #16 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.95 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
Have you tried some of the LEDs that have built in resistors?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 03-25-2019, 03:41 PM   #17 (permalink)
SmoothLoafers
Team Pontiac
i didn’t try any resistors. I thought it would be wierd to raise the load back to the original bulbs when I’m trying to lower load. Might be more complicated then that, but that was my thinking
