Old 11-05-2008, 02:33 AM   #1 (permalink)
Help - Spiffie MPGuino Problem
All,
I installed my Spiffie.org MPGuino tonight and all was well until I went for a drive. When stopped, the GH showed .31 at idle, about right. No speed indication. When driving, and the VSS started to send a signal, the guino would reset, work for a while, speed would read high, reset, finally locked up. Had to remove power to reset. It is connected to the vss+ at the ecu, vss counts set to 8000 for now. Where to go from here?
Old 11-05-2008, 04:48 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Couple suggestions:
1. Triple check your power and ground connections.
2. make sure all the components are in the right place and have the right orientation.
3. make sure there are no "solder bridges", or other loose conductors on or near the board.
4. re-melt your solder joints. Just touch a hot iron to each one.
Old 11-05-2008, 11:16 PM   #3 (permalink)
Success,
I disassembled my dash tonight and rewired the duino to use the signal VSS at the speedometer. Works like a champ! I did retouch all the solder joints and I have my duino hardwired instead of using the phone cord. (I used CAT5 stranded patch cord). I mounted the switches to a small perf board and put them in the dash in front of the steering wheel and they look great. Can hardly see them and they look like they have always been there. I also modified my lcd by removing the polarizing film and rotating it to give the light numbers and dark background. Very easy on the eyes at night. I use the brightness setting 1 and I may end up changing the settings for the 3 preset levels since it is so bright. I don't have it in an enclosure yet, but I will post pics when I am done. On the first try out, I did have the vss set to 8000, but the speed was double what I was actually travelling, so I am using 16000 now. Seems to be very close. Great work and many thanks to all who contribute to this project.
Old 11-05-2008, 11:36 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
for a guino success story.
Old 11-06-2008, 03:50 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
Sweet!
I'm trying the inversion trick right now (for the hud thread).
Old 11-06-2008, 08:17 AM   #6 (permalink)
If you are doing the polarization inversion, I found the best way to remove the adhesive from the glass and film is to rub it off by using a pencil eraser. Don't use acetone! Alcohol is ok to use to clean it up after you remove the bulk of the glue with the eraser. Simply push the goo in one direction with the eraser and it will ball up as you go. My film did not work by simply flipping it over. I actually had to cut it into several pieces to rotate it and still cover the whole glass. Someday, I will get a bigger piece of film and replace the pieces, but for now it looks ok.
Old 11-06-2008, 12:30 PM   #7 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by moorecomp View Post
Success,
Cool, glad to see that you got it working. I pick up my VSS pulses at the wiring going to the speedometer as well. My cars use a VSS buffer (sometimes its part of the ECM, sometimes its not) to clean up the wildly swinging VSS signal and turn it into discrete pulses. And I would think that if vehicles of this vintage did this, most anything newer would as well. My speed reading is very solid.
Id like to see your work sometime when it is all done. Maybe we could meet up again sometime.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-06-2008, 12:36 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
Cool, it looks like that is exactly how the blue LCDs are made. That polarizing film is fun stuff I think I understand why some folks are complaining of glare, I wonder if you can even read the blue LCDs with polarized sunglasses on?
Old 11-06-2008, 12:53 PM   #9 (permalink)
Oh man, you just got me thinking! I wear polarized sunglasses all the time when I am driving. (Sound of me running outside to car) - All is well. I just checked and I can see it fine with the sunglasses on. What looks like glare on mine is actually a glare reducing screen protector applied over the pieces of polarizing film. There are gaps between the two where the pieces of film are put together.
wagonman -
Sure, we can get together again anytime. I will be in Petoskey tomorrow and will be coming back your way in the afternoon. Let me know what a good time would be and where.
Old 11-07-2008, 11:19 AM   #10 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Nope, you can't. I have the blue LCD and two sets of sunglasses, one that polarizes, the other doesn't... If I wear the polarizing ones the screen is basically black. The non-polarizing ones are just fine.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 03:29 PM
iDuino MPGuino wyatt OpenGauge / MPGuino FE computer 146 02-20-2009 12:23 PM
speed on mpguino fluctuates briansavka OpenGauge / MPGuino FE computer 1 08-01-2008 11:06 AM
