Old 11-26-2012, 10:14 AM   #1 (permalink)
TheCav - '04 Chevy Cavalier LS
Hood Insulator
So I noticed I had no under hood insulation. I have a bunch of holes where it seems unsulation would go, but no insulation there.
Anyone know what materials I would put under my hood to help insulate it from the cold. Where would I get such materials?
Old 11-26-2012, 10:48 AM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
well you could try a junkyard and find the factory insulation or you could just try this http://ecomodder.com/forum/showthrea...tml#post339884
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 11-26-2012, 03:10 PM   #3 (permalink)
I might try to find a decent junk yard. Not many near where I live. It will be a drive.
As far as that super fast warm up. I read that thread. I did not give me any solid ideas. Just want to insulate my hood for not to protect my paint as my car turns 10 yrs old.
Mainly looking for a nice insulating material maybe to buy from home depot or menards, maybe even order it. I saw some people had insulation that looked like foil, not sure what that amterial was. Looked easy to keep clean as well.
Old 11-26-2012, 03:15 PM   #4 (permalink)
I got some from this guy not over priced and was shiped the day I paid
EZ Cool Automotive Insulation heat barrier and noise reduction for cars, trucks, classic cars, street rods and much more
The Following 3 Users Say Thank You to groundflyer For This Useful Post:
Pawtuckett (04-10-2013), WesternStarSCR (12-07-2012), YeahPete (12-03-2012)
Old 11-26-2012, 03:39 PM   #5 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Whatever you use, make sure it can handle the heat! I once tried using a tar-backed aluminum roofing product and it melted right off the hood.
Old 11-26-2012, 03:54 PM   #6 (permalink)
the turd - '88 honda civic 4dr DX
90 day: 73.51 mpg (US)
try summitracing.com insulator mat its 4"x6" part #tru-blip11406 price 24.95 it will protect against heat up to 400 deg. . its what i used and my car is 24yrs old
The Following 2 Users Say Thank You to ajjct For This Useful Post:
Old 11-27-2012, 01:56 PM   #7 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
I ended up cutting some cardboard out, then putting a layer of double-bubble foil insulation under that, then a layer of duct tape where any electrical components would touch. It doesn't warm up much faster, but it does keep the engine warmer longer while parked on cold days.
Old 12-07-2012, 04:01 AM   #8 (permalink)
the old boat - '93 Cadillac Deville *removed/modified
90 day: 24.2 mpg (US)
There really isn't much one can do to insulate the hood for engine heat retention.
The foil products R value is relative to the heat passing through and off the side with the foil facing an open space. The foil doesn't 'reflect' heat, it prevents emissivity (coming off). Heat from the engine is going the other way. In fact you are basically insulating against heat gain from the sun hitting the hood and radiating into the engine bay.
The R value of the heat going upward against the foil bubble stuff would be less the R 1.
And then when the vehicle is moving, the air flow is going to push that heat.
As well as the hood being metal and contacting other points of the car (conduction).
Apart from sound deadening, it is really futile.
A foil topped hood (outside) that is kept clean would turn the hood into an insulator as long as you reduced the contact points of the metal hood with the car or used a different hood material.
The Following User Says Thank You to ctgottapee For This Useful Post:
Old 12-07-2012, 06:18 AM   #9 (permalink)
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
I just saw a How It's Made episode on Roxul brand of insulation, made from 'rock wool'. It can handle high heat and is water proof as well. Anyone try that, as it seems if it strategically secured under the hood, it has great heat retaining and sound deadening properties. I have no clue on cost or availability but they melt slag, coke and salt rock to melt it and spin it into fibers.
Old 12-07-2012, 06:41 AM   #10 (permalink)
I disagree. Clearly the space is insulatable. And I want it to not get much hotter when it's moving, the desired function being to retain heat longer when parked.
aluminum, foil, hood insulation
