Old 03-05-2011, 06:33 PM   #11 (permalink)
Originally Posted by Joenavy85 View Post
I'm going on a roadtrip this summer to California which will require me to put a hitch basket on the back for carrying extra gear. maybe i can design it into a sort of hitch mounted semi-boat tail??
In fact there is such a product on the market.
Old 03-05-2011, 06:36 PM   #12 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
i've seen the big enclosed hitch mounted pods, but i'm thinking more along the line of building it onto one of the hitch baskets, and have the entire assembly be able to slide back to access the spare tire.
Old 03-05-2011, 07:03 PM   #13 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Look up aerohead's posts (he could very well be our best resident aero authority), in about 1/4 of them he states and restates that it is the rear end of the vehicle that benefits the most from aeromods.
Sure, but Phil also has a deflector on the hood of his T100 to reduce the (apparent) windshield angle.
Old 03-05-2011, 07:04 PM   #14 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I think I saw this in a post somewhere - the suggestion that you could build an aero-optimized boattail that would attach to a hitch. So rather than drill and screw to the sheet metal, it mounts and dismounts. And if you get pulled over you say "It's a luggage carrier". Which it will be, because it has a big space inside and a hinged or removable access panel.
Or maybe I thought of it - - who knows. Beyond my modding skills, but it might be a workable idea. Needs a full set of working lights and a license plate mounting location.
Coast long and prosper.
Old 03-05-2011, 07:27 PM   #15 (permalink)
how's this look??
Old 03-05-2011, 07:29 PM   #16 (permalink)
^^^the giant cowl induction looking hood i'm wanting to avoid, just not my taste
Old 03-06-2011, 09:37 PM   #17 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Really?
Can you find that?
Yep.
The belly will help.The diffuser will help but it won't function until everything upstream is clean.So I would recommend you start at the nose and work back.
In Reason we Trust
The Following 2 Users Say Thank You to AeroModder For This Useful Post:
Cd (02-14-2015), wyatt (03-07-2011)
Old 03-06-2011, 09:42 PM   #18 (permalink)
Oh for ****s sake, he's talking about a diffuser, of course in that location it needs something other than total turbulent chaos to work.
Look at the rest of aerohead's posts; THIS guy is talking about the TOPSIDE.
Old 03-06-2011, 09:51 PM   #19 (permalink)
Versa - '12 Nissan Versa Hatchback S
90 day: 39.65 mpg (US)
Thanks aeromodder, I couldn't remember where I had seen that.
Frank Lee, you are correct in a boattail will help, and the back end of almost every vehicle on the road today is in horrible need to fixing. From what I have gathered on this site though is you will not realize enough potential from a boattail/kammback until you have smoothed out most of the car starting at the front.
Old 03-06-2011, 10:19 PM   #20 (permalink)
Originally Posted by aerohead
t vago,I intentionally left the 'front' of the template simplified to honor pure fluid dynamic minimum drag for sub-transonic flow road vehicle aerodynamics.
Any modern vehicle has a 'good enough' front end for attached flow.--------------------------------------------------------------------------
The importance of the Template is its treatment of the vehicle aft-body.This is where the drag is.
As an ecommodder though,the question is,are you going to totally re-design the front of your car,or clean up the back.
Front mods may do little for performance,as I proved to myself at Bonneville.
Rear mods however will make tremendous difference to performance,and I also proved that to myself at Bonneville,and the open road.
The templates emphasis is on a vehicles aft-body,as this is where the lion's share of drag occurs.
Most contemporary automobiles have a
'good enough' fore-body,that good flow from there is assumed
The template,as described in the first two portions of the thread,reduces the criteria for its use to a single element,height.That's all one needs to create an aft-body with zero separation.
http://ecomodder.com/forum/showthrea...tml#post221932
aerohead (03-08-2011)
