Old 05-21-2016, 12:47 AM   #11 (permalink)
He-man's Avatar
Rocket - '99 Chevrolet Corvette
90 day: 31.51 mpg (US)
Pooter - '01 Honda Insight
90 day: 66.9 mpg (US)
I have not tried to put this on yet.
With the ridiculously cold temperatures we have been having I need to at least try.
Only problem with putting this on is its about an inch thick and I am already running a much taller than stock edelbrock RPM air gap intake manifold and taller than stock edelbrock 650 carb.
Did you ever give it a try?
Old 05-21-2016, 01:43 PM   #12 (permalink)
If vaporizing carburetors made a significant or dramatic difference in fuel economy, then the vehicles/engines that were made to run on propane would have shown similar/dramatic improvements in FE.
they didn't.
Yes, even after accounting for the difference in energy density/BTU's etc, they just didn't.
Could it make some difference in driveability and a slight improvement in FE if all you do is short trips?
...maybe....
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
Old 05-21-2016, 02:32 PM   #13 (permalink)
I have not been able to work on it, been in Afghanistan lately and the engine I was going to use it on is at the machine shop.
they didn't.
...maybe....
That's what I usually say.
And yes its more for winter and/or short trips.
Old 05-22-2016, 12:20 PM   #14 (permalink)
When I first read the title of your thread I thought this might be about the vapor carburetor/turbo arrangement Smokey Yunick experimented (with rather spectacular results).
Pontiac Fiero Hot Air Engine Setup - Circle Track Magazine
http://www.hotrod.com/how-to/engine/...-vapor-engine/
http://www.eng-tips.com/viewthread.cfm?qid=78116
Old 05-23-2016, 12:25 PM   #15 (permalink)
Thanks for the bump to this thread.
And welcome to the thread. But, the Smokey Yunick Engine has been discussed in other threads. Do a search and you should be able to find some. Also, some of our members have done on-going work that directly or indirectly touches on the subject. Iveyjh and PfgPro have posts on similar conceptual work, whether they know it or not.
Oil Pan4's work is less esoteric and more practical and less about over all fuel economy and more about cold weather drive ability and economy.
And thanks for the link to the Engineering Tips discussion. I was involved in that years ago and it bore some fruit if you have the background and temperament to dig through it all.
Last edited by RustyLugNut; 05-23-2016 at 12:36 PM.. Reason: Spelling and formatting.
The Following 2 Users Say Thank You to RustyLugNut For This Useful Post:
iveyjh (05-24-2016), pgfpro (05-23-2016)
Old 05-24-2016, 08:08 PM   #16 (permalink)
This engine is getting lean burn, high compression 11:1, heated fuel, warmed air and likely water methanol injection.
solarguy (05-25-2016)
Old 05-25-2016, 09:08 AM   #17 (permalink)
...eagerly await data...
Old 12-30-2016, 07:31 PM   #18 (permalink)
The Ford carburetor plate holes do not line up with the square bore.
I am going to examine it closer and see if I can drill the holes with out going onto the water jacket.
I want to try this so if the Ford carb plate isn't workable then I want to make one.
Old 01-05-2017, 11:36 AM   #19 (permalink)
Well I screwed up.
When looking for a way to make the carb plate line up by drilling holes I discovered it does in fact line up.
I thought those old fords used square bore carburetors and it turns out that they do.
The hose nipples were 5/8, rotted to about 13mm so they need to go. I will cut them off and drill then to fit what evet pipe thread tap is convenient and put 3/8 hose barbs on there.
Old 01-05-2017, 10:58 PM   #20 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
The plat appears to be designed to accommodate a Holly's front /rear fuel bowls and metering blocks. ?can you turn it 90° to accommodate Edelbrock's side and side bowls and jets .
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
carburetor, fuel vapor, fuel vaporizer, hot fuel, vapor carb
