Old 03-27-2013, 02:28 AM   #31 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Does this sticker make me look fat?
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
The Following User Says Thank You to H-Man For This Useful Post:
GeekForLife (04-05-2013)
Old 03-27-2013, 02:50 PM   #32 (permalink)
High Mileage Lover
Sophia - '13 Fiat 500
Send a message via AIM to Atheria Send a message via Yahoo to Atheria
Ha! Good one...
I found the instantaneous mpg sensor today and it goes to just -- when I take my foot off the gas, so maybe my Fiat does have that deceleration feature. That sensor makes you become obsessive though.
I love my cute Fiat 500, Sophia!
Old 03-27-2013, 03:13 PM   #33 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
You have no idea. I have daily logs for almost 30,000 miles now.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 03-27-2013, 03:30 PM   #34 (permalink)
...beats walking...
Ha! Good one...
...obsessively aware of what affects your MPG, and by how much!
Old 03-27-2013, 10:20 PM   #35 (permalink)
High Mileage Lover
Noooo! My Sophia Fiat!! :-(
A stupid SUV kicked up a rock in the lane next to me and it hit Sophia's windshield making a big chip! ARGH!! She's only a week and a half old! I'm so pissed! I've got to get this repaired fast as it's the type that will easily turn into a major crack.
Atheria
Old 03-28-2013, 07:59 AM   #36 (permalink)
MPG is not linear police
ciderbarrel's Avatar
Ciderbarrel's P*2 - '22 Polestar 2
90 day: 108.13 mpg (US)
Ciderbarrel's Civic - '08 Honda Civic LX
90 day: 31.56 mpg (US)
Not all MPGs are the same...
I was totally excited when after my first 117 miles, I got 48.5 mpg!
I was expecting to get 50 mpg on this fill-up, but nooooo....I averaged only 38.2 mpg!
***warning, long boring math ahead***
***Short version for the tl;dr crowd (apologies to people who have already seen this in my last 239023094 posts, it's a pet peeve on mine) *** changes in MPG can be misleading. You dropping 10 MPG isn't the same increase of fuel consumption as someone going from 100 MPG to 90 MPG (smaller increase of fuel consumption as you) nor 20 MPG to 10 MPG (larger increase of fuel consumption as you)
***long version starts here***
Just to put things into perspective, because changes in MPG can be misleading, these are the MPG figures converted into gallons used per 100 miles (G/100M):
48.5 MPG = 2.06186 G/100M
38.2 MPG = 2.61780 G/100M
That change of 10.3 MPG was an increase of approx 0.556 gallons per 100 miles. If you traveled the same 117 miles at the same MPG, you consumed 3.06283 gallons on the 2nd tank and 2.41238 gallons on the 1st one, for only a difference of 0.65045 gallons (about $2.458 more in gas at $3.779 a gallon)
If we apply that 0.556 G/100M difference in fuel consumption to a different car:
22.50225(repeating) MPG = 4.444 G/100M
20.0 MPG = 5.0 G/100M
That is a difference of 0.556 as well. So you're 10 MPG drop is the same as someone else's 2.50225(repeating) drop in MPG. Same amount of increase in fuel consumption, just a difference in expression of distance traveled per set volume instead of volume of fuel consumed over a set distance.
At the other extreme, it would be like someone who got 100 MPG (1 G/100M) dropping to 64.26735 MPG (1.556 G/100M) because their fuel consumption also increased 0.556 gallons per 100 miles.
Moral of the story: Do not get so hung up on MPG changes because they are not comparable to each other. Your 10 MPG drop is someone else's 35.7326 MPG drop and a different person's 2.50225 MPG drop. All of them consumed the exact same amount of extra fuel per set distance.
Old 03-28-2013, 04:06 PM   #37 (permalink)
High Mileage Lover
Oh dear God...
I'm so lost! ;-)
Thank you for that rather thorough explanation!
What is odd comparing my Fiat to my old Scion is that the RPMs do not go down when I take my foot off the gas like my Scion's did.
Atheria (at a glass place getting my windshield repaired)
Old 03-28-2013, 05:02 PM   #38 (permalink)
90 day: 49.01 mpg (US)
It is a manual, so if you leave it in gear the engine revs according to the speed you move.
If your Scion had an auto without lock-up or with disengage then of course the revs will go down if the load does too. If it has a CVT then sure the revs go down. Unless, like me, you give it so little that it cruises in its most extended position.
Old 03-28-2013, 06:43 PM   #39 (permalink)
Yeah, what RedDevil said. You need the foot off the gas and the clutch engaged (pressed in) to effectively coast with manual transmission.
Old 03-28-2013, 08:43 PM   #40 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I think my post got lost so ill say it again, your engine has a compression ratio of 10.8:1 and it NEEDS premium fuel.
fiat
