Old 08-09-2010, 08:09 AM   #11 (permalink)
The point of wheels skirts is to keep airflow attached to the rear of the car. I'd go with as full of a skirt as you can.
Old 08-09-2010, 01:50 PM   #12 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Ok I did some work on it today, I made a brace for the bottom so that I can get the right shape.
Here is the bracket I will be using to hold the brace and skirt on.
question is how to do the top. I had two ideas:
Use a hinge so that I can fold it open (for tire rotation).
or
just a bracket
what would you do?
The Following User Says Thank You to Weather Spotter For This Useful Post:
TOOQIKK (09-02-2011)
Old 08-09-2010, 03:02 PM   #13 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Back when I was driving my Vibe, it responded well to a change to synthetic oil and transmission fluid change to the tune of nearly 2mpg.
Never got around to changing the tires to LRR, but I consistently drove them @ 50 psi with no issue, I also gutted the rear end of the car by removing the back seats and leaving the spare snce it was always just me in the car.
I also resculpted the nose which helped me stay well above 40mpg throughout my time, but I never got around to lowering the vehicle or adding wheel shirts etc ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 08-09-2010, 04:27 PM   #14 (permalink)
Wiki Mod
Trikkonceptz, thanks for the advice! I run Amsoil in my trans and engine, I noticed smoother shifting and longer coasting. I run my ties at 44psi, any over that and the ride gets very bumpy and I did not see it helping past about 44psi.
here is what I got done before it started raining:
Cutting out the sheet metal:
cut piece before bending:
With brace on (right side is only on loosely):
On car (no top attachment):
How does this look?
How would you deal with the gap on the edges? It is due to my bending of the sheet steel not to the exact shape.
Old 08-09-2010, 08:24 PM   #15 (permalink)
Wiki Mod
Update
I got the first one done (except for painting).
Open
closed:
After some adjusting to narrow the gap:
Off for priming:
I should have time to make the other one before the paint come in. My car color is special order at the auto parts store. I also need to get the car washed before I can epoxy on the right (front of car) side lower bracket. I my also add some epoxy to the hinge mount to give it more strength (epoxying the back side of the screws should make them fun to take off).
One note on what I did. I made a paper outline of the wheel well then added .5" to .75" to it before cutting. I then bent int the extra material to form a rounded edge so as not to rub the car. It also allowed for size tweaking. These tabs also should help keep air from getting under the skirt.
The Following 4 Users Say Thank You to Weather Spotter For This Useful Post:
Arragonis (08-12-2010), KamperBob (08-10-2010), KITT222 (01-01-2011), TOOQIKK (09-02-2011)
Old 08-10-2010, 06:44 AM   #16 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by Weather Spotter View Post
Looking forward to ABA results. Do you have a ScanGauge?
Cheers
KB
Old 08-10-2010, 07:07 AM   #17 (permalink)
Looks much better after you closed the gap up. Nice job.
Old 08-10-2010, 07:38 AM   #18 (permalink)
Wiki Mod
Cheers
KB
Yes I do (since last October and it has paid for it's self already)!
Doing the fine detail bending took some time but cut the gap in half! I made it with an extra 3/4" bent in so that I could play with it since I was not sure that my paper template was just right.
Daox, what is your ideal testing method?
ABA? If so, how sound I do it? for a whole tank at a time (right now my driving is not consistent at all)?
Coast down? There are some nice back county roads out my way that I could use for hours without seeing any other cars http://dotable.com/images/smilies/turtle.gif
Both?
I would think that to do this right I would need to test with both sides on so that the change is bigger (will stand out from the noise better). It will be a few days till I can make the #2 skirt.
Old 08-10-2010, 07:41 AM   #19 (permalink)
Darin wrote a good article a while back on how to test.
http://ecomodder.com/forum/showthrea...ery-11445.html
That being said, I'd do a constant speed test and measure the difference in MPG on a scangauge/mpguino if you have either. If you don't, a coast down is all you can do.
The Following User Says Thank You to Daox For This Useful Post:
Weather Spotter (08-10-2010)
Old 08-10-2010, 08:11 AM   #20 (permalink)
Wiki Mod
With a scangauge, How to I reset it for each run?
Daox's 2003 Matrix Build Thread Daox EcoModding Central 76 01-11-2016 01:47 PM
A new best tank for the Toyota Matrix: 48 MPG Daox Success Stories 10 09-24-2010 01:47 PM
Rick's Rental Reviews: 2003-2008 Pontiac Vibe / Toyota Matrix (35.5 MPG) MetroMPG EcoModder Blog Discussion 0 06-19-2008 11:26 PM
Better Gas Mileage from my 06 Matrix thevisionseeker Hypermiling / EcoDriver's Ed 9 06-02-2008 04:11 PM
An inkling of what the Matrix is worth Daox Hypermiling / EcoDriver's Ed 12 06-02-2008 02:56 PM
