Old 08-02-2009, 06:01 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
How-To: Honda CRX Rear Wiper Delete/Removal
I had to buy the Honda plug off of ebay for $15 since Honda didn't have any in stock. If there is an HF in the junkyard near you it should be easy enough to pick one up, but I'm not that lucky.
Begin by popping off the covering.
Then take off the 12mm bolt holding the arm on.
It took a little bit of wrenching to get off but try to be careful.
Yay, it's off!
Now we need to go inside to remove the wiper motor.
First you need to get the plastic off, which is a pain. Remove the brake light cover, unbolt the brake lights, and then you'll need to pry off the sides first. After that there are some big metal clips angled parallel to the hatch glass holding the plastic on on the side closest to the rear-view glass. You'll want to careful pry the plastic up towards the roof of the car, as if you were trying to slide the plastic piece up. After you do this you can see the wiper motor, which you will need to unbolt.
Once unbolted, remove this cap.
Unscrew the big nut, the last thing holding the motor up. 23mm.
Be careful if you close the hatch, I smashed one of my brake lights.
Really fine glass got everywhere.
Don't forget to unplug the motor.
And there you have it, the motor.
Now you have a hole to fix.
Shove the plug you bought into the hole, and voila!
I would suggest RainXing the window to make sure you have some visibility.
Old 08-03-2009, 01:12 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The HF doesn't have a plug. It just doesn't have the cutout there for the wiper motor arm to come through.
Old 08-03-2009, 01:15 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
SVOboy, you shouldn't be running around barefooted where there's broken glass
How much would you say the motor and wiper weigh?
Old 08-03-2009, 01:18 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
I wonder why honda makes a plug then.
The whole thing probably weighs about 5 pounds, but the main issue for me wasn't weight, it was aerodynamics, though it is always nice to get a 2 for 1 deal
Old 08-03-2009, 01:20 AM   #5 (permalink)
You just lost .01 Cd. You should be happy.
Old 08-03-2009, 01:24 AM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Actually, I've heard the .01 is from both the wiper and the thinner tires on the HF, so I'm not sure. Thinner tires would normally just mean a lower A so I don't know if what I read was confusing the issue or if the width also creates a large enough wake to up the cd more.
Old 08-03-2009, 01:25 AM   #7 (permalink)
You mean you don't have 155/80 tires?!?!
Old 08-03-2009, 01:27 AM   #8 (permalink)
Dartmouth 2010
SVOboy's Avatar
I forget, to be honest. I will be rolling trading my vx wheels + 60 bucks for insight wheels and potenzas in a week or two
Old 08-03-2009, 01:33 AM   #9 (permalink)
Oh, speaking of the Insight mods you plan on doing, you ARE going to fit those rear skirts, right?
Old 08-03-2009, 01:43 AM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
That's probably the least practical of any insight -> crx mod.
It would be neat to cut off the insight front clip and weld it up to the crx though
The Following User Says Thank You to SVOboy For This Useful Post:
HyperMileQC (10-09-2011)
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Tuft Testing 2nd Gen Honda CRX Rear Glass SVOboy Aerodynamics 29 02-11-2010 01:51 PM
Single front wiper crx? chipX Aerodynamics 28 12-05-2009 03:57 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
1991 Honda CRX - New Here... Hi, Everyone! adam62882 Introductions 4 09-28-2008 10:35 PM
