Old 11-06-2018, 02:30 PM   #21 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Let's say this is for a liquid cooled stationary backup generator and size, weight aren't really a problem.
Any idea how long thy last?
Cost?
Also How do you get the 300c necessary to fire these up at full power?
Exhaust?
Old 11-06-2018, 02:41 PM   #22 (permalink)
I would be using it at full power.
Probably heat it with liquid coolant.
If I use 300C the wires insulation would melt.
Old 11-06-2018, 05:24 PM   #23 (permalink)
IamIan's Avatar
From what I've read .. baring some type of mechanical failure .. the semi-conductor part itself of most TEGs .. Roughly the same rate of degradation as most solar cell semi-conductor degradation .. about ~0.5% to ~1% per year (+/- context and material specifics).
Mechanical failure can result from allot of sources .. vibration , temperature changing cycles of expansion/contraction , sheer , impact , etc.
Soo , in ~20 years of use , it would be roughly 'fair' to assume you will drop down / loose somewhere around ~15% reduced power output (all else being equal).
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
Old 11-07-2018, 02:16 AM   #24 (permalink)
100 mpg 1 tonne truck
teknomage2012's Avatar
Z - '77 Datsun 280Z 2+2 custom
90 day: 31.85 mpg (US)
Bumble Bee - '06 www.mpgtrikes.com nomaOmatic x1
90 day: 76.46 mpg (US)
VW Caddy Pickup Truck - '81 Volkswagen Rabbit Caddy Pickup Truck
90 day: 33.1 mpg (US)
KLR - '09 Kowasaki KLR 650 Dual Sport
90 day: 54.65 mpg (US)
The Juggernaught - '65 Gillig 35' motor coach
90 day: 6.55 mpg (US)
hummingbird - '81 Volkswagen rabbit vx
90 day: 165.09 mpg (US)
HD Ruby - '12 nissan leaf sl
90 day: 99.66 mpg (US)
Eco Ruby - '12 Nissan Leaf Sl
90 day: 169.6 mpg (US)
Billy - '01 Dodge 2500 2wd
90 day: 18.38 mpg (US)
Send a message via ICQ to teknomage2012 Send a message via Yahoo to teknomage2012
I get the over 300c to fire up our TEG thermalelectric boiler by burning wood pellets, then through a grid tie inverter we put the energy from the wood pellets into our Nissan LEAF to the tune of 2 free round trips to town per day. Meanwhile the heat produced makes hot showers and goes I to our home hydronic heating loop.
Total system efficiency is near 100%
How to get a 100 mpg 1 tone crew cab truck for under $10,000; buy a nissan leaf!
Old 11-07-2018, 12:33 PM   #25 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Do you have a picture of your setup?
How many modules?
Old 11-09-2018, 05:25 AM   #26 (permalink)
105 40x40 mm TEG modules in this boiler from hastyheat.com
https://youtu.be/oTijbSC8y6A
Old 11-09-2018, 06:28 AM   #27 (permalink)
Interesting video series on burning a TEG up by overspec thermal loading...
Synopsis if you have a good cooler you won't melt the solder out, so pour the heat to them...
https://youtu.be/Ya40vwpTCf4
Old 11-09-2018, 12:30 PM   #28 (permalink)
So you have to have a solid cooling system.
Old 12-08-2018, 05:07 PM   #29 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I went down the TEG rabbit hole again today in my mind and did a little reading. This is an especially tantalizing quote from an article with some good images and research summaries, too:
"The Honda system used a simple design of a thin flat rectangular box with TEGs placed on the top and bottom surfaces. Liquid cooling was used in this design. The system consisted of 32 30 mm × 30 mm TEGs and produced a maximum of approximately 500 W. The claimed fuel consumption reduction is 3%."
SOURCE: B. Orra, A. Akbarzadeha, M. Mochizukib, and R. Singhb, "A review of car waste heat recovery systems utilising thermoelectric generators and heat pipes," Applied Thermal Engineering, Vol. 101 (2016), 490-495.
https://www.sciencedirect.com/scienc...01128X#bib0060
Daox (12-08-2018)
Old 12-17-2018, 09:19 AM   #30 (permalink)
Cyborg ECU
An example of someone bringing a 100w TEG system to market. An ICE is kinda like a stove, right? Quite pricey at +$1000.00 USD, especially without TEGs included:
"Introducing the first plug & play TEG Water Cooled System with an accessory solar input, battery charger and patent pending prioritization for active cooling. Our Patent Pending Tegpro Multi TEG & Solar Battery Charger with Pump Priority is a mulit-input charge controller that prioritizes power to the active cooling system onboard. It also displays voltage and current while charging your battery system.With the factory settings the unit can charge up to 14.4 VDC (can be set at factory set from 12 - 28.8 VDC, so please ask tell us!) and will accept up to 30 V DC inputs. ..."
https://172.98.64.46/thermoelectric-...oled-teg-sytem
