Old 08-21-2018, 12:48 AM   #51 (permalink)
Took front clip off the Prius and ran the tape measure.
What are the numbers? Wheel track? top to bottom of the drive train?
Old 08-21-2018, 07:22 AM   #52 (permalink)
Hoopie
Hoopie's Avatar
These are the measurements I took when doing my research. I’ll get the new numbers today and post them later.
The Following 5 Users Say Thank You to Hoopie For This Useful Post:
aerohead (11-25-2020), Bill the Engineer (08-21-2018), California98Civic (08-21-2018), slowmover (11-14-2018), Xist (08-21-2018)
Old 08-21-2018, 10:18 AM   #53 (permalink)
Track was wheel on or wheel off? I remember ghias using shallow offset rims
Old 08-21-2018, 10:41 AM   #54 (permalink)
Front track — 7.7 inches. Sounds like 3" fender flares (the Ghia body overhangs the wheels more than the Prius) unless you go for a lifted off-road look.
Old 08-21-2018, 11:51 AM   #55 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.01 mpg (US)
That Prius front track is only about a half inch wider than a stock Fiero rear. That gets the juices thinking...
The Following User Says Thank You to elhigh For This Useful Post:
Old 08-21-2018, 07:01 PM   #56 (permalink)
Hoopie
Hoopie's Avatar
Video update
https://youtu.be/svRRcGWAYi0
The Following 3 Users Say Thank You to Hoopie For This Useful Post:
Bill the Engineer (08-21-2018), Daox (08-21-2018), Xist (11-13-2018)
Old 08-21-2018, 10:00 PM   #57 (permalink)
If the struts fall inboard the valley in the fender that's good. Are the 32" and 34" measurements to the ground or to the bottom of the chassis?
Old 08-21-2018, 10:48 PM   #58 (permalink)
Hoopie
Hoopie's Avatar
The measurements are from the ground.
The Following 2 Users Say Thank You to Hoopie For This Useful Post:
Bill the Engineer (08-25-2018), freebeard (08-22-2018)
Old 08-22-2018, 10:15 PM   #59 (permalink)
Hoopie
Hoopie's Avatar
Pria Ghia pt3 video update
https://youtu.be/E_Xu8uACbJM
Plan on driving it while I prepare the Prius platform.
The Following User Says Thank You to Hoopie For This Useful Post:
Bill the Engineer (08-23-2018)
Old 08-24-2018, 01:37 PM   #60 (permalink)
no driving noises in the ghia. darn. was wondering how thrashed it really was.
