10-27-2018, 11:44 AM
#181 (permalink)
Hence the need for totaled Prii.
The pan carries the VIN.
10-29-2018, 10:18 AM
#182 (permalink)
Iirc, the tunnel has the vin at both ends, one under the rear seat, the other at the end near the access hole so you can verify without taking out the seat. Had a buddy do a pan swap and got caught by the CHP
10-29-2018, 10:28 AM
#183 (permalink)
Might be the "mystery" number
One thing done in the late '60s was "hidden" vins. It might have been the same time the vin plates appeared in the lower portion of the windshield. The numbers were pretty easy to find, plus word-of-mouth got around. Nice to know about the beetles having it too. The rear stamp seemed to get butchered a lot on dune buggies.
10-29-2018, 03:21 PM
#184 (permalink)
Aerokee - '97 Jeep Cherokee XJ sport 90 day: 18.22 mpg (US) Scrambler - '74 Honda CL200 Motorcycle 90 day: 55 mpg (US)
I'm wondering how the Karmann Ghia body shell will hold up without a frame. VW did not design it to be a unibody car. Technology has advanced quite a bit and today's cars use special steel and structure techniques to get away without a frame underneath the body. The door pillars, roof, and even the windshield are all major parts of the unibody. I do not know if that is true for a Prius, maybe it is special or something. You did successful drive it around a parking lot without the top of the unibody.
What do you think?
10-29-2018, 11:05 PM
#185 (permalink)
home of the odd vehicles
Generally speaking most of a moder cars structure is still on the bottom,
If anything the Ghia body is more supported in this configuration than stock
10-30-2018, 10:32 AM
#186 (permalink)
Hoopie I think you will find this infomration helpful if you haven't seen it already: https://jalopnik.com/this-1968-volks...ata-1825036646
Apparently, putting air-cooled VWs on Miata chassis is kinda a thing.
The Following 3 Users Say Thank You to mannydantyla For This Useful Post:
10-31-2018, 06:00 PM
#187 (permalink)
Must be nice to have a two post lift in the back yard.
11-05-2018, 08:03 PM
#188 (permalink)
Much of the structural integrity on the body of an old-school Volkswagen doesn't actually depend on the floorpan.
11-05-2018, 10:05 PM
#189 (permalink)
Karmann Eclectric
Karmann Ghia Unibody
Indeed, most of a Ghia's strength is in the body. The VW pan is a floppy thing, with only the central spine providing some structure. A Ghia Cabriolet flexes tremendously over undulating terrain, but a coupe is pretty stiff, as it forms a full box once bolted to the pan. Here's some photos of my pan-off project, where I beefed up the pressed sheet metal with a square tube outer rail and boxed in the rear quarter pans to carry batteries.
https://karmanneclectric.blogspot.co...beginning.html
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
11-06-2018, 10:56 AM
#190 (permalink)
Not sure I agree. All the dune buggies with plastic bodies says the pan should be fairly rigid since the body doesn't add much strength off road.
