04-05-2019, 12:09 AM
#271 (permalink)
Looking good! Really coming together!
My current Ecotec project...
My last Ecotec project...
04-06-2019, 05:47 PM
#272 (permalink)
Hoopie
Rerouted filler neck and epa bits
The Following 2 Users Say Thank You to Hoopie For This Useful Post:
04-06-2019, 05:51 PM
#273 (permalink)
Hoopie
Filler neck
Filler neck found it’s way in the truck nicely.
The Following 4 Users Say Thank You to Hoopie For This Useful Post:
04-06-2019, 07:11 PM
#274 (permalink)
That works.
My concern is the rocker panels. Maybe you could follow the original curve and then hang a side skirt on that bottom flange.
04-08-2019, 04:33 PM
#275 (permalink)
Hoopie
Weight
I put the Ghia on the scale today. Numbers are looking good. I still have to add some sheet metal, but this is close to the final weight. My best guess is that I’ll come in around 2400 pounds.
The Following 3 Users Say Thank You to Hoopie For This Useful Post:
04-12-2019, 03:54 AM
#276 (permalink)
Have you never considered replacing the filler cap for one that could be accessible from the outside?
04-17-2019, 10:29 PM
#277 (permalink)
Cyborg ECU
That is almost exactly the stock curb weight of a 1998 Civic DX Coupe 5MT. You have a very light Prius, there.
04-17-2019, 11:59 PM
#278 (permalink)
If this was a race car I would need to know if you were in the seat and the fuel tank load. But I would want a little more weight in the rear, and I would need to know the front bar size? LOL
Looks great, I love your work!
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
04-24-2019, 12:21 PM
#279 (permalink)
Aerokee - '97 Jeep Cherokee XJ sport 90 day: 18.22 mpg (US) Scrambler - '74 Honda CL200 Motorcycle 90 day: 55 mpg (US)
Hey man I'm pretty impressed with how it's all fitting. Your seating position is perfect, dash fits perfectly, etc. Tires are a little wide but it's not terrible, they're likely already +45et offset so not much you can do.
I don't blame you for putting off the rocker panels but it might be time to rip that band-aid off. Here's how I made mine: https://youtu.be/nXk434kHBww
My VW body is a lot lower on the car than how you did yours, so it's a different situation but I think the principle will be the same. Bend some metal and weld it onto the VW door sill and the chassis pinch seam. I had to get the body as low as possible because the seating position of the Miata was so low that if the body wasn too high then I wouldn't be able to see out of the windshield! Of course I had fender clearance issues because it was "slammed" so I lifted the suspension 3 inches. Just finished it a few days ago actually and took it on a test drive.
The Following 2 Users Say Thank You to mannydantyla For This Useful Post:
04-26-2019, 02:26 PM
#280 (permalink)
The weight my pickup imposes on each tire.
