Old 06-08-2019, 09:44 AM   #21 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I believe the engine must run at higher speeds even when not accelerating to run the trans fluid pump.
These engines don't have a lean burn, but the cam is special and allows LIVC, late intake valve closing.
Old 06-08-2019, 04:37 PM   #22 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by Tahoe_Hybrid View Post
I'll be replacing the air filter as well as it's clogged Just waiting on the part i need (the torx tool to open it)
Wait, wait, wait--you need a torx bit to open the engine air filter housing?
I'm having flashbacks to the Chrysler products I've owned, which used a mix of English and metric sizes, and you needed 5 million tools to do anything. Meanwhile, my last two cars--both Japanese--you can literally take apart in their entirety with 6 metric sockets, a Philips head screwdriver, and a pair of needlenose pliers.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 06-08-2019, 11:55 PM   #23 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
[QUOTE=ksa8907;599735]I believe the engine must run at higher speeds even when not accelerating to run the trans fluid pump.
no it has a Aux transmission pump a AUX water pump as well
It falls back to mild hybrid if a failure occurred...
I think I found a Active Fuel Management mpg exploit... hack (aka THE hidden "3rd mode"). 2̶ ̶M̶o̶d̶e̶
But I can get Regenration.. to kick in and able to accelerate in 4 banger mode the RPM drops to 1,000 RPM in 4 banger ( it vibrates a little though since it's technically speaking it should not be at 1k rpm) in v4 mode .. the minimum RPM for V4 is 1200rpm for it to be stable or it vibrates slightly
this exploit
could be quite promising...AFM exploit
the v4 a (AFM exploit) you can even force a regeneration event while forcing it to accelerate on a down hill while still in v4(important to have more POWER(electrical power) & speed when you get to the next hill to maximize MPG)..
other wise if its normal regeneration and you take foot off the gas, you might I MEAN might gain a few mph in speed...
I suspect this AFM exploit might work great hahah...
Came in at 24MPG With A/C on medium fan. set to 60F..
Computer reading 24.1MPG average.
EPA BOOST huge claims i should have lost 25% OR more fuel economy...
4.00%- total lost at the A/C @ 60F medium fan speed.. it was 85F outside and 90-95F inside (Black SUV)
or if by EPA claims 18.5 mpg which is 25% loss
Old 06-09-2019, 01:37 AM   #24 (permalink)
Yes Security so people don't steal your "used" air filter
Old 06-09-2019, 09:55 AM   #25 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Probably closer to:
Security, so owners aren’t tempted to work on their own cars.
35 mpg sounds a little optimistic, but may be possible if you drive slow enough. I did a 5000 mile trip in my V6 accord going usually 65 +-5. I got 41.45 MPG overall.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 06-09-2019, 12:40 PM   #26 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
The new body style 99 trucks didn’t have torx, I don’t know how long they went before switching but I think they were in all the full size for a couple years before the change. Originally they had a combination flat blade and #3 Phillips. Problem was the 2 at the lower end, kinda hard to reach and being angled, didn’t take long before the heads were rounded off bad. So what do you do? you have to push down hard as you turn. Doing this helped a lot of people over tighten those screws and split the air box lid at the screw. Gm knew they were selling too many air box lids, and the torx was part of the redesign. They didn’t just start out being dicks about it, they just started out with one of the most often removed fasteners being hard to access.
Old 06-09-2019, 12:45 PM   #27 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.95 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
My Insight is the same way, except that half the screws on the hybrid battery panel are torx, presumably to discourage the average joe from accessing it readily.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 06-09-2019, 01:46 PM   #28 (permalink)
well the GM cars used clips to hold it on and it did just fine..
the HV battery uses standard bolts on it
Old 06-09-2019, 01:49 PM   #29 (permalink)
Moderator
Vman455's Avatar
Sounds like the problem is, if they had designed it thoughtfully in the first place they wouldn't have had to deal with the broken fastener issues.
Old 06-10-2019, 09:01 PM   #30 (permalink)
Switching over from chevron 91 octane to Shell V-Power 91 octane
They claim to have a new formulation
we will see if it "helps or hurts MPG"
