Old 02-28-2014, 01:24 PM   #11 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
Originally Posted by doviatt View Post
The starter in my last Metro must have been from an army tank. It worked flawlessly the entire time I owned the car. I'm not sure how long it served the previous owner. The cool part is, the last six months of this wonderful cars life was driven without a clutch after it (clutch) failed. The starter was used at every stop to not only start the engine but to move the car, in first gear to get it going.
That's why older 4Runners have a clutch safety deactivation switch. If you stall them in the middle of nowhere and need to get out of a tough situation, you can push the button, and the starter will engage with your foot off the clutch pedal, using the starter to get the thing moving. Of course, all cars in the "old days" (I'm guessing pre '80s?) had this as they didn't have the safety switch to start with, and I have used it more than once to get one of my broken POS's out of an intersection rather than push it ha ha.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 02-28-2014, 01:26 PM   #12 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Whenever I hear stories like that, I keep thinking: "must install clutch switch over-ride switch..." and then forget until the next story.
I've only needed to do it once (pre-clutch-switch car), but it could happen again.
Old 02-28-2014, 04:30 PM   #13 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
I disabled the clutch starter lockout switch on the aerocivic over a decade ago since there are many situations where it is useful to be able to put the car in 1st or 2nd and crank the starter to move the car or to drive with a busted clutch..
aerocivic.com
Old 02-28-2014, 06:49 PM   #14 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Yeah--there was a clutch override switch in my old '91 Toyota pickup. Never had to use it, though.
Of course, all this is moot for me now since I bought a car that turns the engine off and starts by itself. It kind of takes some of the fun out of it.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 02-28-2014, 06:56 PM   #15 (permalink)
doviatt's Avatar
Grey Goose (Retired) - '89 Geo Metro LSI 4 door hatch back
Last 3: 57.16 mpg (US)
Tweety - '91 Geo Metro Convertible -2 Door convertible LSI
90 day: 43.97 mpg (US)
Shadow - '02 Honda Shadow VT1100
90 day: 43.46 mpg (US)
Sonic - '07 Honda CBR1000RR
90 day: 42.69 mpg (US)
Filmore - '84 Volkswagen Vanagon
90 day: 20.9 mpg (US)
So does the Prius use the electric drive to start the ICE rather than have a starter motor?
Old 02-28-2014, 10:56 PM   #16 (permalink)
XYZ
In the usual course of a day (excluding shutting your engine off at traffic lights) how many times on average did you need to park and leave your car and then restart the engine?
Old 02-28-2014, 11:15 PM   #17 (permalink)
Moderator
Vman455's Avatar
From what I've read, yes. One of the motors spins the ICE up to 1000 rpm to start. It's very seamless driving around.
Old 02-28-2014, 11:53 PM   #18 (permalink)
doviatt's Avatar
It was a 60 mile round trip commute every week day for work. To be fair most of it was freeway.
I can't exclude traffic lights
in this scenario because I had to stop at lights and keeping the engine running was NOT an option (how would I get it back into gear?). I will admit to rolling stops on the stop signs most of the time. 16 starts worst cast and 8-10 average with good luck with lights, traffic, etc.
I will admit this wasn't fun nor amusing. It is a real story though. I still have the starter just incase I want to put this trusted unit into my current Metro.
Old 03-01-2014, 07:03 AM   #19 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Yes - Prius dosen't have stater or generator, but uses the EV motor for it all.
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 03-01-2014, 12:25 PM   #20 (permalink)
XYZ
So, prior to the clutch problem, typically how many times per day did you need to park and leave the car? (If I understand correctly it was only once per day?)
