12-11-2018, 03:10 PM
#21 (permalink)
Funny thing: I spotted a g1 Insight a couple of weeks ago (has become quite a rare sight around here - maybe 1 sighting a year).
Even more rare! A CRX showed up in town, same generation as yours. The lady is apparently daily driving it.
12-11-2018, 03:18 PM
#22 (permalink)
Too many cars
Originally Posted by Ecky
That's definitely not right. I don't know how it's wired but it's possible the temperature switch for the radiator fan is not the same sensor for the gauge. I'd burp it, and if that doesn't help, replace the thermostat.
Do you have the full wiring diagrams for the car?
I do have the wiring diagrams downloaded from IC. I haven't tried to diagnose anything yet. Usually the fan, gauge and ECU have different sending units.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
12-11-2018, 03:40 PM
#23 (permalink)
Too many cars
Will this help me?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following 4 Users Say Thank You to Gasoline Fumes For This Useful Post:
12-11-2018, 04:29 PM
#24 (permalink)
Too many cars
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
12-15-2018, 11:42 PM
#25 (permalink)
Too many cars
Burping the air out of the cooling system stopped the overheating and the fans are working now!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following 3 Users Say Thank You to Gasoline Fumes For This Useful Post:
12-17-2018, 10:18 AM
#26 (permalink)
Thalmaturge
Yeah, burping these engines takes a weirdly long time. My work Chevy pickup you can just keep adding coolant to the tank each time you stop driving until it stops going down. The Insight you have to have on perfectly level ground while idling and waving 3 witch hazel branches and doing the traditional coolant bleeding dance under only a 3/4 waxing moon while alternating the idle between exactly 641 and 1366 rpms every 3.15 seconds.
The Following 3 Users Say Thank You to samwichse For This Useful Post:
12-17-2018, 01:08 PM
#27 (permalink)
Love the the CRX beside the Insight. Separated at birth... by a couple of decades and a bit more engineering.
12-17-2018, 08:45 PM
#28 (permalink)
Too many cars
They are pretty similar!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
12-20-2018, 01:19 AM
#29 (permalink)
Engine-Off-Coast
Dang I did not realize the CRX was LIGHTER than the Insight!!
12-20-2018, 04:15 AM
#30 (permalink)
Too many cars
The '88 HF was the lightest 2nd gen CRX. The '91 Si was over 2100 lbs. The Insight's weight is impressive considering it has ABS, SRS, IMA, EPS, A/C, PW, keyless power locks, dual power mirrors and a rear wiper. Honda put a lot of effort into keeping the Insight light. Not much effort was made to keep the CRX light. It was just a much simpler car. It's fun comparing the two, literally side-by-side.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
