Old 09-24-2013, 12:10 AM   #1 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.3 mpg (US)
I Know Nothing About Car Systems
I am starting this thread, because sometimes during research, I come across something that I have heard of, but don't know how it works or I am driving and thinking about car stuff, but don't know the answer. So when that comes up, I will have somewhere to go to get the answer (assuming I can't find it elsewhere).
I'll start with an easy one: Why don't we use a refrigerant like R134A to cool the engine (through the radiator) rather than a coolant like ethylene glycol? Is there a benefit that EG has over R134A?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 09-24-2013, 06:25 AM   #2 (permalink)
Pressure, complexity and the risk of leaks.
jeff88 (09-24-2013)
Old 09-24-2013, 08:45 AM   #3 (permalink)
Add cost to the list (kinda goes with complexity I guess).
Old 09-24-2013, 01:29 PM   #4 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Add safety, goes with pressure but 134a isn't exactly as environmentally friendly as sliced bread, antifreeze (take your pic of which) is an order of magnitude safer in multiple ways.
If you had that much 134a in one place and it let off it could cause inhalation dangers, not to mention pressure and environmental harm.
The Following User Says Thank You to rmay635703 For This Useful Post:
jeff88 (09-24-2013)
Old 09-24-2013, 01:30 PM   #5 (permalink)
rmay635703's Avatar
Makes me wonder though, could the AC system be "heat" powered off the exhaust, sans compressor?
Might be an interesting and very old concept.
Old 09-24-2013, 01:37 PM   #6 (permalink)
Lots of Questions
How would that work? Are you suggesting a turbo generator powering an electric A/C? Or maybe the exhaust drives the pulley like a belt?
Best EM Quotes:
Old 09-24-2013, 01:52 PM   #7 (permalink)
bryn's Avatar
sputnik - '93 oldsmobile silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 ford clubwagon E-350 xlt
very excelant - '92 honda civic vx
good luck, should work just fine. Absorption refrigerator - Wikipedia, the free encyclopedia
The Following User Says Thank You to bryn For This Useful Post:
jeff88 (09-24-2013)
Old 09-25-2013, 01:40 AM   #8 (permalink)
I've already considered to use some sort of absorption refrigeration setup to recover heat from the engine itself and the exhaust and to use it both for intake cooling (with a coil inside the air intake to act like an intercooler) and as a replacement for a regular air conditioneer.
Old 09-25-2013, 03:23 AM   #9 (permalink)
Lots of Questions
Any reason why I couldn't use propylene glycol instead of EG? It doesn't have as low of a freezing point, but I don't really have to worry about that in this weather! Is there another reason why I wouldn't want to use it?
Also as a side note, why do we not use oil as a coolant? (I know that the engine oil does help with cooling, but I'm not talking about that). Couldn't one use a really thin, maybe 0w-10, oil in a coolant loop? I would think (and read) oil is a better vehicle for heat pick-up and removal.
Best EM Quotes:
Old 09-25-2013, 09:11 AM   #10 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Cost is the only reason I've found, some people do use it.
Again, cost, it would cost you $52 per gallon, oil also it gets thicker when you cool it so you'd need larger passages in the radiator so you'd need more of it and thus more cost and weight, air cooled VW's had oil coolers on them, some motorcycles do as well, but in general they all run much hotter and their cooling is not as even.
