Old 08-29-2015, 10:21 PM   #21 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
They use a slightly different definition of "endurance" than I do... I'm thinking this will be on the frail end of the spectrum as in, a big pothole might take this out vs a more heavily built conventional car. That's not saying I don't like it.
Weight is the enemy of endurance. A brick dropped from a height will break into a million pieces that a block of styrofoam will survive (even in a vacuum).
If it doesn't meet crash safety standards, then there's no reason it can't be much lighter than VW's XL1. It will likely make use of the same loop hole that kit cars do.
Batteries weight more than fuel per equivalent energy content, but EV's are designed to only carry one day's fuel supply on board (while the ICE carries one weeks). By the sound of it the batteries won't be very big 10kWh is only around 220lbs.
Old 08-30-2015, 07:35 AM   #22 (permalink)
IamIan's Avatar
Originally Posted by e*clipse View Post
The traditional usage was predicated on the assumption that all vehicles will use a gas tank, exhaust system, etc. I'm merely extending the concept for a fair comparison.
Traditional usage .. has been used for wind turbine powertrains , water wheel powertrains , etc .. (gas tank), (exhaust system), etc.. assumptions are not part of the accepted/conventional usage of the terminology .. Just like if someone says 'wheel' .. they are not talking about the 'shaft' that may or may not be attached to the wheel .. even if the 'shaft' could be part of the system.
It's not a big deal .. just making your own person changes to word definitions.
Yes; I am including those because it seems to me all components involved in an system need to be included.
makes sense .. and I'll agree such considerations are good.
Soo when do you include:
The air (Oxygen) needed for the ICE ? ... like rockets vs jets.
And .. When do you include all the horribly low efficiency , high weight, large volume, long time, steps it takes for that gasoline solar energy storage system ? ... After all we have these steps included for the PV+Battery solar energy storage system.
Personally I would gladly swap the solar panels for more batteries, and put more solar panels into my grid-tied home system.
You probably have a very good chance to get more yearly kwh from the solar panels that way .. although you would than be throwing away almost all the solar energy hitting the car's surface .. And probably not enough weight saved on vehicle to gain another battery string.
Also keep in mind .. The solar panels on the car itself are a crucial part of it's marketing .. without them on the car .. they are just another BEV .. it is the amount of solar energy harvest that is integrated into the car that allows it to even have a tiny chance to stand out and distinguish itself from other BEVs.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
Old 08-30-2015, 04:27 PM   #23 (permalink)
EcoModding Jack
nimblemotors's Avatar
Right, crucial to their bull**** lying about it being solar powered.
It is just THIS BS that makes people with real cars have a more difficult time selling them. I hear from people looking at my car, "why don't you have solar panels on it and make it solar powered"... like that other car does (that car that exists only on computer screens from the marketing dept)
That and have alternators or fans to recharge itself while it drives down the highway. Gosh if your car doesn't have that it isn't very good.
The Following User Says Thank You to nimblemotors For This Useful Post:
Fat Charlie (08-31-2015)
Old 08-30-2015, 05:59 PM   #24 (permalink)
IamIan's Avatar
You just described exactly my point .. and why the solar panels on the car itself is a core part of their design target market.
People want it .. if you don't have what they want .. it makes it harder for you to sell to them something that doesn't have what they want.
Old 08-30-2015, 07:07 PM   #25 (permalink)
Tomorrow's solar EV... Today
https://wausau.craigslist.org/mcy/5137421194.html
MotoTec Solar Electric Go Kart 24v Red - $200 (plover)
fuel: electric
transmission: automatic
safety tips
prohibited items
product recalls
avoiding scams
Scratch and dent
The MotoTec Solar Electric Go Kart provides up to a 2 hour ride time with its integrated 4watt monocrystalline silicon solar panel on the rear wing that continuously recharges the go kart while in use. It's powered by a 16Ah 24v battery pack and 350 Watt DC motor that can reach speeds of 15mph. The solar panel can also charge the go kart while not in use or with the battery charger in 4-6 hours. This go kart comes standard with 9 inch pneumatic tires for a variety of terrain and easy to use disc brakes.
Motor: 350 Watt DC Electric Motor
Top Speed: 15 MPH
Battery: One 24v 16AH Lead Acid
Solar Panel: Integrated 4W Monocrystal Silicon (13x9 inch panel)
Battery Charger: Included
Ride Time: 2 Hours (compared to 45min)
Frame: Steel
Rims: Aluminum 2 piece
Tires: 9 inch Pneumatic (9x3.5-4)
Brakes: Rear disc with hand lever
Green: Zero Emissions
Recommended Age: 13+
Max Rider Weight: 150 lbs
Product Dimensions: 48x33x21 inches
Product Weight: 80 lbs
Box Dimensions: 49x35x15
Box Weight: 103 lbs
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
freebeard (08-30-2015), UltArc (09-02-2015)
Old 08-30-2015, 08:44 PM   #26 (permalink)
Now we're talkin'. What more does a simple person meed?
Old 08-30-2015, 11:36 PM   #27 (permalink)
Permanent Apprentice
Ok, a few things about my personal changes to defintions.
1) I think you have a very good point about that. I bristle when I hear the word "industry" associated with banking or insurance - WTF?
2) OTOH, makers of ICE powered vehicles have lots of ways to alter certain specifications to their favor. I just installed a new motor in a Toyota 4runner. There's a few large containers of fluids that need to be recycled - motor oil, transmission ATF, cooling water, power steering, fluid. You'd be surprised how much oil a AT actually holds when you completely drain it and then drop the pan to change the filter. About 2X the amount required than an "oil change." Then engine also required about 50% more than an "oil change."
3) It's not exactly clear what "dry weight" is, because I've seen different uses of the term. For example, I was recently looking into purchasing a 1968 Triumph GT-6. There were several different weight specs involved - where "dry weight" was actually dry - no oil, coolant or fuel. Then there was an intermediate - no fuel, then there was a "ready to go" weight.
4) Not including the weight of the gas can be pretty large amount of weight - say 15 gallons X 6 pounds/gallon = 90 lbs. That's NOT SPLITTING HAIRS. That is nearly the weight of one of the 50kW motor/gearboxes I'm using to power my car.
In fact, here are some #'s from ICE parts I've taken off my Mitsubishi Eclipse:
Gas tank itself is about 29 lbs.
The evaporative emmisions stuff associated with just STORING FUEL is about 10lbs.
Exhaust system (exhaust pipe, muffler, catalytic converter): 45lbs
Radiator: 17lbs
Intercooler: 7lbs
rear driveshaft: 35lbs
rear differential: 66lbs
This does not include all the random hoses, etc involved but we are at 209lbs!!
That's the weight of TWO MORE MGR's! In other words, the stuff that auto industry would like to have people ignore when it comes to weight easily total the weight of 3 power units that can put out 50kW each! 150kW for FREE! (weight wise )
Notice that I didn't include the weight of the motor/transmission - that can easily account for the battery weight.
In other words, if someone wants to compare the weight of an ICE car with a BEV car, they need to accurately evaluate everything involved. Usually people include the motor, transmission and battery for the BEV. If they merely include the engine and transmission for a FWD car, they will be off by quite a bit.
If the "traditional" usage is more accurately "powertrain" then fine - I'll use it. It would be nice if one word could be used to describe all this.
Regarding the steps in the fuel system - I couldn't agree more. Here's another example of the ICE/oil complanies ignoring part of the problem. It would be great to find a way to include all the energy involved in pumping crude oil, transporting it, refining it, then tranporting the fuel to the gas station. While ICE proponents are very quick to point out stuff like "coal powered EV's or the carbon footprint of solar panels, they are very quite about the energy/pollution involved with petroleum products.
I honestly fully support efforts to make a vehicle light. I think automakers have gone far into "bloatware" and vehicles would significantly benefit from well thought out weight reduction. There's certainly room to take advantage of the EV drivetrain in making a lightweight vehicle in a nice lightwight design. For example, using the battery box as a structural part of the vehicle chassis like the EV-1. Using a carbon fiber tube frame chassis isn't taking advantage of these possiblilites, it's merely using a new material in an old way.
However, it's probably their marketing hype that bugs me most. Solar "infinite" range. Claims that the vehicle will handle like a sports car when powered with a 40kW motor, riding on skinny solar racer tires. I don't think they're going to get people to cough up $300,000 for a sporty car that can barely keep up with a Miata on a straight road.
The Following User Says Thank You to e*clipse For This Useful Post:
IamIan (08-31-2015)
Old 08-31-2015, 03:05 AM   #28 (permalink)
90 day: 49.01 mpg (US)
$300.000 would buy you as much Tesla as 4 wheels can bear plus a trailer with a gigantic fold-out PV solar array.
It is hard to imagine a setting in which the Immortus could beat that setup.
Another setup:
Buy the Tesla and spend the change on home PV arrays.
You'd make enough electricity to power a whole fleet of EVs.
The power company will pay something for that and you get it back for free through the high speed charging network.
You'd not only drive free, you'd make money!
But what if there is a zombie attack?
Yeah, and what if there is a twister? Or just a gale for that matter?
I would prefer the Tesla.
IamIan (08-31-2015)
Old 08-31-2015, 08:24 AM   #29 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Um... For the same reason you don't have a fuel refinery on a trailer behind your car?
Transmission type Efficiency
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
RedDevil (09-01-2015), Xist (09-09-2015)
Old 09-01-2015, 03:31 AM   #30 (permalink)
The refinery isn't even enough. You need the whole system.
A carsized refinery may even be doable, but the drilling for oil bit is a bore.
Xist (09-09-2015)
bev, solar
