Old 02-09-2013, 01:07 PM   #531 (permalink)
So this photo brings up an interesting question. Should I ever have time to finish the damn thing, when I arrive at the final shape of my boat tail I intend to have an A&P friend of mine cover it in aluminum. So it will be similar to this awesome creation in the photo.
The question is this; you've aluminum skin over a steel frame. How do you keep dissimilar metal corrosion at a minimum or eliminate it?
Old 02-09-2013, 01:49 PM   #532 (permalink)
Silver Bullet - '02 VW Golf TDi
Your A&P friend will know to use zinc chromate primer between the aluminum and the steel.
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
The Following User Says Thank You to Stan For This Useful Post:
aerohead (02-09-2013)
Old 02-09-2013, 05:43 PM   #533 (permalink)
radioranger
I dont know if zinc chromate is a good idea as its pretty toxic, even though airplanes are full of the stuff. I think plain old epoxy would be better, you never hear of Shelby cobras corroding that much , course they probably aren't used in the snow or you could just insulate the two where they might get moisture between them.
Old 02-09-2013, 11:00 PM   #534 (permalink)
This car looks like an attempt to copy the Panhard LM64.
Old 02-10-2013, 06:23 AM   #535 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Another cool image of that car:
aerohead (11-08-2013)
Old 02-10-2013, 07:10 AM   #536 (permalink)
Spend the rest of the weekend on Google and research the heck out of the topic.
Caulk and adhesives will be heavy, but will also have benefits of preventing air and water infiltration by sealing the joints.
Building paper (roofing felt) will also be heavy. Tyvek will be much lighter, perhaps it can be spray mounted to the back of the aluminum prior to mounting.
Sound absorption materials will be expensive in addition to being heavy, but also have attractive attributes such as insulative qualities.
Perhaps a double sided tape will allow you to mount, seal and separate the two materials without additional mechanical fasteners. Call up the 3M technical assistance people and see what they recommend.
You also have weird things such as "insulative paints " which may be an option worth researching.
You just need a "bond breaker", but be aware that moisture and condensation can transfer chemicals between the two metals allowing a small degree of migration. Not as much damage as bare contact, but nothing is perfect short of total encapsulation (epoxy paint?).
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 02-12-2013, 11:19 AM   #537 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
THIS SITE IS GOLD. OMG.
Inter Action
The Following User Says Thank You to Sven7 For This Useful Post:
Old 02-12-2013, 01:26 PM   #538 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
My bicycle is on the the first page.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
Sven7 (02-12-2013)
Old 02-12-2013, 01:38 PM   #539 (permalink)
Which one...the "Varna Diablo"?
Old 02-12-2013, 01:46 PM   #540 (permalink)
Do more with less
It is listed with the diablo but it is called the Varna2. An older version of the diablo that I modified to diablo specs. It has been to 62 mph as the original version ridden by Sam in the early 90s.
My modified version went to 66.6 powered by a woman, Lisa Vetterlein. It broke the record in 2005.
Later we had it ridden by a guy, Rob English, who did some efforts in one hour competition with some success, setting a British record. It is hanging on my wall somewhat like a hunter who would hang the head of his rhino.
If the right circumstances were to pop up. It could be brought down off the wall and raced again. Not a bad career for a bicycle. Top mens record and top womans record.
Noah Webster, 1787
The Following 3 Users Say Thank You to Varn For This Useful Post:
aerohead (02-16-2013), Frank Lee (02-12-2013), TEiN (02-13-2013)
