05-15-2016, 05:39 PM
#2001 (permalink)
The 1965 Barracuda offered a V8 but the Hemi Under Glass was the rear engine show car.
05-15-2016, 11:50 PM
#2002 (permalink)
05-16-2016, 12:44 PM
#2003 (permalink)
Permanent Lurker
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k) 90 day: 47.08 mpg (US)
Sorry for probably stupid question, but what is hemi? My dictionary doesn't help. Type of an engine?
05-16-2016, 01:39 PM
#2004 (permalink)
The term 'hemi' is short for hemispherical combustion chamber. The part of the cylinder head where the intake and exhaust are located is shaped as a dome. Dodge cars and trucks use this in V8 engines and it may be a trade name for them.
05-16-2016, 01:48 PM
#2005 (permalink)
Permanent Lurker
Thank you.
05-16-2016, 02:41 PM
#2006 (permalink)
Would you like to know more?
https://en.wikipedia.org/wiki/Hemisp...ustion_chamber
https://en.wikipedia.org/wiki/Chrysler_Hemi_engine
While USAians got V-6 and V-8s, the Oztralians got an inline six:
https://en.wikipedia.org/wiki/Chrysler_Hemi-6_Engine
The Hemi-6 is a pushrod O.H.V. (overhead valve) engine, with combustion chambers comprising about 35% of the top of the globe. This creates what is known as a low hemispherical shaped chamber. Although the Hemi-6 does not contain truly hemispherical combustion chambers, the "Hemi" moniker was used primarily for its marketing cachet based on the reputation of Chrysler's 1950s-1970s (true) Hemi V8 engines.
The Hemi-6 valves are 18 degrees (included angle) along the crankshaft axis opposed valves, with intake valves as large as 1.96". The 6 intake and 6 exhaust valves open toward each other, and into the center of the combustion chamber. In addition, both valves are slightly inclined across the crankshaft axis (similar to a conventional "wedge" chamber). The cylinder head is a non-crossflow design, meaning the 6 intake and 6 exhaust ports are on the same (left, Australian and British passenger's side) of the engine.
I like the little Hemis: - 1952-53 Desoto 276c.i.
- 1953-54 Dodge 241c.i.
Cut down into a slant-four, you'd have a 2-liter engine.
05-20-2016, 01:13 AM
#2007 (permalink)
05-20-2016, 01:20 AM
#2008 (permalink)
Aw, I was hoping for an interesting aerodynamic car.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
05-20-2016, 11:25 AM
#2009 (permalink)
Sorry, but there wasn't an Interesting Aerodynamic headlight thread.
You could have provided an example; like this:
http://goawaygarage.blogspot.com/
05-20-2016, 11:34 AM
#2010 (permalink)
This count?
The Following User Says Thank You to ennored For This Useful Post:
