12-09-2019, 10:58 PM
#3341 (permalink)
So now I'm thinking about a homemade plywood Cybertruck.
12-10-2019, 03:13 PM
#3342 (permalink)
Master procastinator
Plybertruck?
The Following 2 Users Say Thank You to iikhod For This Useful Post:
12-10-2019, 03:54 PM
#3343 (permalink)
12-10-2019, 04:09 PM
#3344 (permalink)
It looks like it would evade radar, at least.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
12-10-2019, 10:26 PM
#3345 (permalink)
That's an interesting point. When I looked at radar-proofing cars, the last big problem was the headlight reflectors. The LED lighting and front chamfers would reduce the signature.
12-11-2019, 02:18 PM
#3346 (permalink)
I think that the actual intent is to borrow the glamour of the latest military hardware. The 50s had a lot of styling borrowed from fighter aircraft, and when they went supersonic, that was copied too, completely out of place.
12-11-2019, 04:27 PM
#3347 (permalink)
Reading minds is a loser-think game. I suspect the design was derived from first principles along the lines of an arthropod shell. The skin is 3mm thick. The inner structure is conventionally thin. This puts mass where it is most efficient.
The unpainted shell with 'metal glass' windows will be essentially immortal.
12-11-2019, 04:40 PM
#3348 (permalink)
Shells are never flat or faceted, but curved to spread impact loads. The Citroen 2CV and Ford Trimotor used corrugated steel to get sufficient rigidity from thin sheets. Steel, being dense, is very inefficient as a flat panel unless it is used as faces on a sandwich with a suitable core. A plywood panel would be equally hammer-resistant at much lower weight.
Reason: extra word
12-11-2019, 05:29 PM
#3349 (permalink)
Hence my comment at Permalink #3342
12-16-2019, 01:05 PM
#3350 (permalink)
I know this one has been posted, but it is good to "retune" your eyes, once in a while:
