09-18-2020, 05:21 PM
#3561 (permalink)
I suspect the mirroring is a simplification to remove the underbody as a consideration.
There's a lot going on in the center of that full body.
Agreed the spats and breakover angles are in order. I'm still a fan of the Magic B*tt Trumpet.
09-18-2020, 05:35 PM
#3562 (permalink)
The relative motion between underbody and ground is just one of the myriad complications in fluid motion. The template is only the very beginning of wisdom, not the whole science.
The Following 3 Users Say Thank You to Bicycle Bob For This Useful Post:
09-23-2020, 10:42 AM
#3563 (permalink)
mirror-image ground simulation
I reread every word in Hucho's book after I got home Friday. I flagged every citation involving the 'mirror-image' ground simulation technique. As well as dozens of other streamlining criteria which failed to make it into Hucho's 'Subject index.'
I packed Julian's book plus Hucho's into my backpack, and managed to get to town this morning without it. I'll try for Friday.
The earliest I can find a source for the mirror-image technique is pre-1922, from Paul Jaray, of the Zeppelin Werke. Paul was an airship designer for them and is responsible for introducing the longitudinally-asymmetrical, 'teardrop, body of revolution,' airship hull, originally invented by Frenchman, Pierre Julienne, in the 18th-Century.
Jaray's work is presented in 'AERODYNAMIK DES KRAFTFAHRZEUG', self-published by Baron Reinhard von Koenig-Fachsenfeld, 1951, who is actually 'Kamm'.
09-23-2020, 11:23 AM
#3564 (permalink)
Originally Posted by aerohead
That use of the template would violate the ground reflection, mirror image, and fineness ratio, blowing the Cd all to hell.
There's only one way to use the template.
In another recent thread you mentioned no need for rear diffuser if the underbelly behind the rear wheels were at 2.8 degrees or less.
I assume this rule of thumb is for a range of heights normal to road cars, let's say between 4-8 inches?
The template posted through improperly used by the article's author has a rear departure angle of approx. 2.8 degrees, right?
Right answer using wrong method, or does that Miata need a rear diffuser for an un-yet stated reason?
09-23-2020, 02:34 PM
#3565 (permalink)
diffuser
1) the 2.8-degree upsweep IS the diffuser. It begins at the beginning of the rear wheelhouse. It has the lowest drag observable for a diffuser.
2) as to ground clearance, the body must be able to clear 10-degrees ( approach) at the nose, 10-degrees ( breakover ) between the axles, and 16-degrees ( departure ) at the rear. The 'template' respects the three criteria.
3) the Miata has it's own Sports Car Club of America ( SCCA ) race car category. Many owners take them to the 'TRACK' on weekends. Elapsed time on the course is the primary interest. Winners will have balanced downforce and top speed for the winning edge.
Technically, a diffuser will not function if the onset flow coming to it is perturbed. You'll see mid-engined supercars ducting the exhaust through the body to the wake area just so the can create a really clean belly and diffuser.
I'm not sure what the SCCA rulebook allows in competition.
The Miatas I've seen are all roadsters. No roof! Seems like they'd be going after splitters and rear wings as far as the law allowed.
09-23-2020, 04:45 PM
#3566 (permalink)
Incorrect. The literature is actually all over the place for 'best angle for lowest drag' for a diffuser.
Correct.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
09-24-2020, 04:09 PM
#3567 (permalink)
best angle
Correct.
Of course, the angle is dependent upon the 'length' of the diffuser, as with a prismatic fastback rear slant angle.
From Carr's research, published in Hucho, and an SAE Paper from FIAT, both reported 2.8-degrees as the angle which delivered the drag minimum for the 'long' diffuser. The information is exactly accurate within the context of the source material. That was good enough for me. And a gentleman would allow for the context.
Reason: add data
09-24-2020, 06:10 PM
#3568 (permalink)
Yes, that's the issue.
09-24-2020, 06:20 PM
#3569 (permalink)
09-25-2020, 12:21 PM
#3570 (permalink)
the issue
An adult will consolidate the appropriate prima facie, bona fides supporting their thesis, and tear the opponent a new one with scientific facts.
Your free to say whatever you want, but it's not debate material. Wow us with some peer-reviewed quanta!
