07-28-2011, 03:39 AM
#91 (permalink)
The PRC.
Apologies - I had to go to bed (after emptying the loft of old car books, did I mention I would avoid Google...)
4 valve engine was a Peugeot GP car. There is a link because Bugatti designed a Peugeot car but not the 4 valve one as far as my book said.
On the plus side I now have a pile of old car books to re-read...
I may indulge Google for the fuel filler one though, not being familiar with US cars.
Bendix, who are they ?
EDIT - Lucas, lest we forget...
07-28-2011, 07:24 AM
#92 (permalink)
The PRC.
@Larry - is this car with the unusual filler position a current car, pre or post war ? (as in ww2).
07-28-2011, 08:30 AM
#93 (permalink)
Diesel Addict/No Cure
Originally Posted by Tango Charlie
If Bosch didn't do it, then it had to be Bendix.
SUUUUUURRVEYS SAID,
DINGDINDING!!!!!!!!!
YOU ARE CORRECT!
Take a look at this.......... 1958 DeSoto Electrojector - First electronic fuel injection?
This system was made by Bendix, and if you look carefully, every EFI system we see now is based on it. I believe the rights were sold to Bosch who took it on to its logical conclusion.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
07-28-2011, 08:37 AM
#94 (permalink)
designed a Peugeot car but not the 4 valve o4 valve engine was a Peugeot GP car. There is a link because Bugatti ne as far as my book said.
SUUUUUURRRRRRVEYS SAID,
DINGADINGDING!!!!!!!!
YOU ARE CORRECT!
Take a looksee...............
1913 Peugeot L45 Images, Information and History | Conceptcarz.com
The funny thing about Lucas; if the accountants stayed out of the way, they probably would have been remembered for the most reliable electrics.
The folks in the front office always found a way to cheap out and get away with it. Was reading about the history of Jaguar in the US, and it was said that with some things all it took was an extra .04-.06p per unit to make the switches perfect, but they wouldn't do it.
07-28-2011, 09:59 AM
#95 (permalink)
The PRC.
Funny thing is all the cars in my younger days (up until late 20s) were BL or BL Descendant machines with loads of Lucas badged parts all over - Metros, original Minis mainly. I can't think of a single time I had an electrical failure apart from water in the distributor in a mini which was cured at the factory with a bit of hardboard, and at home with a rubber glove with the fingers removed.
As soon as I got into old MGs and started getting "improved from the original Lucas design" parts I was stranded often - coils, distributors, non-working lights at night - all sorts. It was a little like the MGOC wanted you to have the full "period" experience
No smoke though, thankfully.
07-28-2011, 10:00 AM
#96 (permalink)
The PRC.
Tango - I think you got an answer first, so be our guest and go next.
07-28-2011, 10:09 AM
#97 (permalink)
Never got the answer for the automated manual; want to keep it floating about?
07-28-2011, 10:14 AM
#98 (permalink)
The PRC.
Oops - yep.
Any idea on the filler one too ?
07-28-2011, 10:27 AM
#99 (permalink)
Not at all. I haven't a clue.
07-28-2011, 11:45 AM
#100 (permalink)
5 Gears of Fury
Wait, isn't the gas tank under the seat in a VW van?
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
