Old 08-18-2008, 09:11 PM   #31 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Originally Posted by bbjsw10 View Post
A engine-braking situation normally shuts off the injectors on its own, "Deceleration Fuel Cutoff" leaving key on and coasting down that hill in 5th or 4th would kill injectors. I could be wrong but I know most fuel injected cars do this. Mine does and it is a 91 Metro I am sure a Honda would be the same a little more advanced than my car is.
My 1999 Honda CRV coasts right into 'Fuel Cutoff' when I take my foot off the gas on a good hill (while in 4th or 5th gear).
The Scangauge2 starts displaying 9999.9 MPG.
If I'm coasting down a smaller hill and engine braking is just too much,
Or, I feel the need for speed!! Just shifting into neutral and
letting the engine idle nets me around 50 to 70 MPG while coasting at 30-40 MPH..
Coasting while in Fuel-cutoff is super simple and can be done without doing any wiring..
That SC2 is a great little device for showing how much gas you are wasting going up hills too fast.
I've been using it with the Cruise Control for highway driving.
When I see the display dropping down around 20 MPG going up a hill,
I back off with the CC down button. On the down hill part, I use the
CC up button to apply more speed until I see the MPG hit a peak,
or until I hit the safe speed limit.
I love good long hills where I can hit 65 MPH while getting 40 to 70 MPG..
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 08-22-2008, 10:43 PM   #32 (permalink)
Carbon based lifeform
dentprone's Avatar
Green Rocket - '01 Subaru Forester
Clifford - '76 Dodge M880
RuhRoh - '94 Geo Metro
Thanks for the info, bbjsw10, I'm following the thread closely. Impulse, as an installer, have you run across the sockets for those Bosch style relays? I have used those to make some of my installations a little cleaner.
-Chuck
Watching paint dry?
Check out my blog.......
http://www.mobiblog2500.blogspot.com
Old 08-22-2008, 11:12 PM   #33 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Your welcome.
Old 08-22-2008, 11:13 PM   #34 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Ultimate KILL-SWITCH SHIFTER!
I was lucky enough to find a very slick control knob at the junk-yard today.
It is a joystick from a forklift - cast aluminum with TWO momentary one switches built it.
Perfect for both a kill switch AND a push-button start. Plus, it gives the feel of a jet-fighter!
Sorry no photo. My camera batteries like to die at exactly the wrong time.
Will post one later.
Edit: Hey, just remembered I have a web cam!
Cheaper than THIS and at a much better price.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 08-22-2008, 11:23 PM   #35 (permalink)
Addicted
bbjsw10's Avatar
I gotta see this, sounds pretty bad-a$$. What ride you putting it in?
Old 08-23-2008, 07:54 AM   #36 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Planning on using this stick for a kill-switch setup in my 4-banger Chevy S10 pickup truck.
My YouTube Videos
Old 08-23-2008, 08:52 AM   #37 (permalink)
Addicted
bbjsw10's Avatar
Just saw the picture, I WANT ONE TOO!!! My car is starting to look like a shuttle might as well have a flight stick..
Old 08-31-2008, 01:30 PM   #38 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I should do a writeup of my ignition coil kill switch method. It would be interesting to compare the two methods to see if there's any difference in the way the car stops/restarts.
Old 08-31-2008, 01:41 PM   #39 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
I have GOT to get me one of those!!!!!!!!!
Old 08-31-2008, 02:03 PM   #40 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Would the fuel system keep pumping in fuel if the car is moving in gear with the ignition killed?
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Kill switch accomplished homeworkhome53 DIY / How-to 22 08-11-2011 02:19 PM
Geo Metro Kill Switch Idea? HotRod EcoModding Central 5 01-27-2011 06:13 PM
help W/ Remote Kill Switch Idea 93hatchDX DIY / How-to 21 07-31-2008 03:46 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
