08-20-2015, 05:28 AM
#12 (permalink)
I'm noticing the before and after exposures aren't the same. In the second photo, the sky and trees are brighter, suggesting the shutter or ISO sensitivity was increased to capture more light. Probably a fine light bar, but it annoys me when advertising uses shenanigans.
The Following 5 Users Say Thank You to redpoint5 For This Useful Post:
08-20-2015, 02:06 PM
#13 (permalink)
Moderator
For $10 more, a little work, and the peace of mind of DOT approval, get these instead:
2015 Murano LED Projector System - Closeouts
OEM LED headlights (low- and high-beam) from the 2015 Nissan Murano. Each LED is 11w; I ordered a set today and am going to try retrofitting my stock headlights.
The Following User Says Thank You to Vman455 For This Useful Post:
08-20-2015, 02:44 PM
#14 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
that IS a great price and the cut-off looks good. i would like to get a set for me to try but can't right now. maybe in a couple of weeks. i will buy a set of lights cheap off CL or JY so i won't be without them while i fit them in. thanks for the info.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
08-20-2015, 04:31 PM
#15 (permalink)
I don't know how good of a light bar it is. At only $100 and 52'' long, its hard to say. But it doesn't come with any switches, wires or relays.
I would likely go with a curved, 100 watt bar and whatever it is, it has to be less than 48''.
Yeah I was looking at that after I posted this picture I noticed other light sources appeared brighter.
If a light bar manufacturer claims 30,000 lumens, even if its really only 20,000 lumen that still like adding 20 halogen head lights to the front of your car.
I use two 20 watt LED flood lights and it lights up my most of my 1/3 acre front yard. This is 7.5 times that wattage of my flood lights.
08-20-2015, 05:37 PM
#16 (permalink)
The beam pattern is so wide and tall you could never turn that thing on when on a road with other cars around.
08-20-2015, 07:33 PM
#17 (permalink)
Moderator
I got on there the other day after one of these LED threads popped back up just to see what they had (they've had Prius LED assemblies for sale in the past, so I check occasionally). I was surprised to see these, and apparently they have hundreds of them. Looks like they'll be a lot easier to retrofit than the Prius LEDs to boot, and the fact that you get high beams too makes them a great deal for the price.
08-20-2015, 08:34 PM
#18 (permalink)
Here's a field expedient fix for the LED in an H-4 reflector. I held a piece of cardboard in the beam to judge placement. I though covering the bottom would do it; but it turned out to be the top.
08-20-2015, 08:49 PM
#19 (permalink)
Not banned yet
can you get a night shot on a wall?
08-20-2015, 09:01 PM
#20 (permalink)
OCD Master EcoModder
I'm sure they're ideal for the vehicles they are built for.
Mine is a '96 Accord.
Coast long and prosper.
