Old 05-11-2008, 12:53 AM   #11 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
What happens when you are moving without using the electric motor? Are you gonna have some sort of clutch on it so the back wheels dont turn it?
How about an alternator being turned by the wheels too so you can get some recharging when youre not using the motor.
Sounds like something that would really be useful in stop-and-go traffic.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 05-11-2008, 12:59 AM   #12 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
I am not sure. My original idea was a free wheel like on a bicycle. IE spins freely when no force is applied. I figure "heavy duty" version of that must exist??
Old 05-26-2008, 06:35 PM   #13 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
Ii would love to put an awd axle into my aspire and run a 20hp motor or so. Get the car up to speed, shut off engine or even idle the thing and that would net over 80mpg easy. Scangauges in heavy trucks idling coasting in N say they are getting over 50 mpg over 30 mph. I dont think you'd need all the batteries of a full replacement as you arent using it from a dead stop like OEM hybrids do. Supplementation I think is an angle not many are really considering. Some people with full electric conversions are just charging the batteries and running them down, with no way to recoup power as they drive. You can always just charge your stuff overnight and drain independant of your ICE.
Old 05-26-2008, 06:51 PM   #14 (permalink)
Grrr :-)
Nerys's Avatar
Exactly. Two completely independent system. To the ice it would be like I am suddenly going downhill or something so I could "let off" the gas a bit as the E motor took up some of the drain.
When I get home or get to work I "plug in" to recharge the batteries.
as for offset draining. No I would always be using "all" of the batteries just in different variations of parallel and series connections.
For example lets say I have 6 batteries. Thats 72v. if there 6 in series. what if I do 2 sets of 3 in series and run those sets parallel. Now I have a 36v pack with twice the amps IE still using ALL the batteries IE still evenly discharging them.
I do not care if I only get a 10mpg boost. I do not care if I get NO mpg boost. the ideal is to see if it WORKS at all at a price that can fit in my nearly non existent budget. Thats why It has to be dead simple I can NOT afford a "controller". as soon as one becomes mandatory this project becomes a non starter. I just do not have the cash. If I had that kind of cash lying around I would not be so concerned about fuel economy :-)
If it works at all then the idea has merit THEN I can safely spend some serious cash to making it work well. 3-4 hundred dollars I can afford on a "seat of the pants test" 3 grand I can not.
Old 05-27-2008, 10:13 AM   #15 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I was thinking that converting an all-wheel drive vehicle to engine powers the front - electric powers the rear, could work well.
I don't know enough about how four-wheel drive systems work to know all the specifics of actually doing it.
A "relay" to control the electric motor is called a contactor. You can have multiple contactors that will switch a pack of batteries so that all batteries are used at the same time, but rigged either in parralel or serial. All batteries drain at the same rate this way, but you can make the motor go a couple of speeds. This is a very old-school way of doing it, and it makes loud "clicks" as the contactors turn on and off. Check out a Commuta-Car/Citi-Car to see how those work.
There are a lot of Geo Trackers out there that seem like they would be a good vehicle to experiment on for this type of a project.
I would simply control both the motor and engine manually. Run on electric only around town, then turn on the engine for highway driving.
The biggest downside is that you are carrying the weight of the engine and motor and batteries at all times.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 05-27-2008, 10:56 AM   #16 (permalink)
Grrr :-)
Nerys's Avatar
thats ok bennelson. So does the Prius :-) you know what would be REALLY funny. I mean hilarious funny in a very serious way? If I managed to get 50mpg with my junkyard 96 voyager with a jerry rigged awd electric conversion and no electronics. I think IF this works that well and IF enough of us did it consumers would start to have some serious questions for the likes of toyota GM and other auto makers.
I'm not holding my breath. If I get 40mpg I will be tickled pink. If I get 35mpg it will have been well worth it.
Even at 35mpg this would save me just shy of $84 a month. That means it would pay for itself inside of 5 or 6 months.!! Lets see a prius pay back like that. At 40mpg it would save me $106 a month paying for itself in 4 months.
If I somehow manage 50mpg it would save me $138 a month. Thats $1656.00 in savings PER YEAR for a $400-$500 investment. So yeah I really really hope it works :-) Even if I have to replace the batteries once a YEAR it will still pay for itself almost triple every year.
also it does not matter how the FWD/4WD works bennelson if your car is already FWD only. IE you change nothing except the rear axle. You do not even need the T-Case. If you already have a T-Case IE already have AWD I am not sure how it would go since you would now be REMOVING a drive shaft to connect the EV motor. When I flip a shaft on my cherokee once it LEAKED fluid when I removed the rear yoke (the part of the shaft that goes into the T Case) so something would have to be done with that.
Since I am already FWD only I do not have a T-Case at all to deal with. I am just going to yank the entire rear axle assembly from an AWD voyager once I find one springs and all and just bolt it on. Mount the EV motor and away I go. (in theory :-) hehe
Just got to find a motor :-)
Old 05-27-2008, 11:56 AM   #17 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
I'm liking the idea, however, one thing to keep in mind. When you are not using the electric motor, make sure you have some way to disconnect it from the drive train otherwise it may become something like the alternator causing more resistance to the ICE's FE then just the wheels would be without the motor attached. If I were to do this I would do it as follows.
3 way relay contact switch like you're planning on doing and a normal foot clutch like a car (mainly to keep the acceleration smooth. Hit button number 1, slowly release clutch to accelerate, then, hit button two. By this time the clutch should be unnecessary for the transition, then button three in the same manner as two. Then once you max out button three, you will need to have a lever of sorts to put it in almost like a "neutral" gear, so the motor is no longer contacting the wheels so the wheels can spin "free-ish" as they would have before. Then proceed like you would with the ICE. This would give you a jerry-rigged type hybrid in a sense. However, my only concern is with the "clutch" mechanism and the neutral lever. Those things are going to be more expensive then if you didn't use them, and they are also pretty complex parts of the drive train so they're going to be hard to install / machine.
Personally, I would do a little research into motor controllers and see if you can't actually just make your own variable speed controller. Not only will it allow you to have a smoother acceleration, but it will also increase battery life since contact type controllers are less efficient.
Old 05-27-2008, 12:08 PM   #18 (permalink)
Grrr :-)
Nerys's Avatar
at 3700 pounds I think the mass will smooth things out. Any Motor I get is likely not going to be able to effectively move the vehicle on its own (as if I would be so lucky) I am hoping for something like a Bicycle Sprocket thing. IE you can stop pedaling and it "free spins" I am hoping to find a larger heavy duty version of something like this. would eliminate the need for any clutch or lever.
Worst case I am hoping to do what people do with there alternators. IE removed the electrical load and the alternator free spins for the most part.
Sure it will add "some" load but this increased load should be far far less than the benefit I will gain from the electric motor reducing fuel needs.
For now I am just going to try and "get it working" and see what happens. If it proves unusually effective say I manage to get 50mpg. then I would definitely look into both a controller and regen. IE I could just wait a year and use the saved gas money to buy the parts :-)
If the motor proves powerful enough to handle the load I will first go with a larger batter pack. or work on making a NIMH battery pack.
Old 05-27-2008, 03:09 PM   #19 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
The part that I am planning when I put a rear drive in my metro is to modify the largest alternator I can find to put out 70 volts or so to charge the battery pack with the gas engine. That way if the car is able to drive on electric only once up to speed or whatever the gas motor could just be cycled on and off every so often just to charge the batteries. Then just use a single set of optima or similar batteries that can run the car for a few minutes at full load before needing recharged. Gives the car a lot of flexibility that way by charging it at home or on the road.
I am still looking into different rear drive setups though and if the voyager rear drivetrain is easy to find it might be worth looking into. I figure whatever I end up using I want something common and cheap to find replacement parts for.
If you do find a good awd voyager in a junkyard somewhere take lots of pics of it
Old 05-27-2008, 03:22 PM   #20 (permalink)
Grrr :-)
Nerys's Avatar
Absolutely - I have an obsession with taking pictures :-) hehe
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 71 05-05-2017 03:24 PM
Camry hybrid selling at record pace SVOboy Hybrids 31 05-27-2012 06:32 PM
Malibu Hybrid bennelson Hybrids 17 12-21-2011 10:57 PM
Hybrid buses save NYC money SVOboy Hybrids 2 02-10-2008 04:02 PM
Click and Clack puzzler: SUV or Hybrid? A Familial, MPG Conundrum! MetroMPG General Efficiency Discussion 0 12-20-2007 01:09 PM
