11-25-2022, 05:15 PM
#11 (permalink)
High Altitude Hybrid
Originally Posted by Phase
I wish I could figure out how much fuel my car uses when idling
Easy.
Fill the tank and let it idle until empty.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
11-26-2022, 01:17 AM
#12 (permalink)
Originally Posted by Isaac Zachary
Easy.
thatll take days!!!!!
11-26-2022, 04:42 AM
#13 (permalink)
aero guerrilla
Then just start with 1 gallon. That shouldn't take more 1-2 hours.
What about OBD tools, like ScanGauge?
11-26-2022, 01:06 PM
#14 (permalink)
any obd plug will display gph
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
11-26-2022, 11:46 PM
#15 (permalink)
even on a hybrid that cycles between ev mode and engine mode?
11-27-2022, 12:12 AM
#16 (permalink)
aero guerrilla
Why not?
If the engine is on, you see the fuel consumption.
If not, you see zero.
ScanGauge will not turn off when the engine is killed. This is for hydrids and start-stop engines, but comes in helpful for EOCing hypermilers.
11-27-2022, 02:10 AM
#17 (permalink)
EcoModding Beginner
WJ - '03 Jeep Grand Cherokee Laredo Team E85 90 day: 17.28 mpg (US) ZJ - '94 Jeep Grand Cherokee Laredo
did you check your maf signal and it's sensor temp? usually it's because the temp sensor failed and the car thinks it's -20 outside. by math since my 4.7 uses 0.55gph at idle at 600, i would think an e85 4.0 and 750 would use around 0.8ish on e85. check all of your sensors. one of these has to be wrong. the quickest way is to sniff the tail pipe with a wideband and see if it's rich.
Sensors read correctly (map instead of maf though). I’m building an mpguino with a raspi pico, and I’ll see what my actual fuel consumption is before testing anything else.
11-27-2022, 01:53 PM
#18 (permalink)
What do you think we all use? we all just use scan gauges or now obd2 plug ins and bluetooth to a phone or tablet.
11-28-2022, 09:38 AM
#19 (permalink)
EcoModding Beginner
hayden55, Phase, maybe move this topic to a new thread.
The Following User Says Thank You to FlashStopFall For This Useful Post:
11-28-2022, 01:16 PM
#20 (permalink)
My bad. Need to proactively not do that.
Yup. Go get a obd2 dongle off of amazon and find an app that will pair with it. $20 later you should be able to see your trouble sensor.
The Following User Says Thank You to hayden55 For This Useful Post:
