Old 05-28-2014, 03:20 PM   #11 (permalink)
Volvo 360 - '85 Volvo 360
Peugeot - '01 Peugeot 306
Some pictures, saves me from a couple thousand words! I'll try to keep it short!
When I bought the car, in all it's hideousness.
After a lot of welding and mending I changed the old worn down 2 liter carb'ed engine to a 2 liter injection engine.
Installed a vacuumgauge and oilpressuregauge together with some other things. Lowering springs, better shocks, poly bushes.
Two years later I wanted more power, so in came the 2.3 liter (b230fb) from a Volvo 940.
Then an electric fan for more power
Did some slalomming
Then the eco interest showed up, so I made a front undertray
And because the car narrows at the bottom, made some front tire deflectors
Started prepping for a grillblock, sealing the gaps in front of the rad
Got some more gauges for oilpressure and volts
And bmw 320 mirrors, which are a lot more aeroshaped then the original mirrors
so in short, some of the performance upgrades are also good for fuel economy.
The original carb differential happens to have the longest gearing available, together with the five-speed this is quite nice.
Lowered the car 2"
Electric fan instead of one on the crank
New engine with better management (lmm, lambda sensor)
Front undertray
Better mirrors
Future mods will be
Turbo camshaft, short duration, short overlap, small valve opening
Full undertray
Grillblock
Partial kamback
Engine cut-off switch
Hoping to break the 40 MPG!
The Following User Says Thank You to Joris For This Useful Post:
RedDevil (05-28-2014)
Old 05-28-2014, 03:39 PM   #12 (permalink)
90 day: 49.01 mpg (US)
Ah, the bonnet hitches in the front.
That is a pity, as though it makes it easier to raise it on the rear it also means there is nothing to catch it in a collision, so that easy raise would be quite dangerous unless you weld in a heavy slot beam or such.
Any chance for a longer gear ratio? How high does it rev in top gear at highway speed?
That 2.3 engine should have enough torque to power it under 1500 RPM at 100 kmph.
Old 05-28-2014, 05:17 PM   #13 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
I wouldn't turbo, I'd do a b230kh. If you must have a turbo, find a b204ft.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 05-28-2014, 07:27 PM   #14 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.62 mpg (US)
I miss my 240
He's talking about installing the turbo camshaft, not a full turbo. Interesting approach.
Neat car, I've never seen a 300 series before.
Old 05-28-2014, 07:34 PM   #15 (permalink)
Originally Posted by elhigh View Post
I miss my 240
Force of habit, opps. A T cam is a good low lift approach, if you can't find an M. I would advance it a few degrees to take advantage of the tall gearing. What injection you running the k-jet, LH 2.0, 2.2, or 2.4? Edit, you said 940, so that'd be 2.4.
Old 05-29-2014, 10:10 AM   #16 (permalink)
Yes, it's a b230fb with lh 2.4 management. I'm trying to find a T-cam but everybody wants to sell only the whole engine.
The b230hk was made for being fuel efficient, with high compression heron head en T-cam. So I can't wait to try that cam in my engine with better management. Only the 9.3 compression I have won't help.
Edit: it's at 2000 RPM at 50MPH or 80km/h, 2500 RPM at 60MPH or 100km/h and 3000 RPM at 70MPH or 115km/h.
On the highway I mostly try to stay under 60MPH.
Old 05-29-2014, 08:08 PM   #17 (permalink)
Have you never considered a Diesel swap?
Old 05-31-2014, 10:43 AM   #18 (permalink)
There are diesel versions of this car, called the volvo 340 diesel. These diesels get 40-45MPG. However, because of new tax rules it is way to expensive to drive an old diesel.
Old 06-01-2014, 08:22 AM   #19 (permalink)
Did some tuft-testing yesterday.
As expected the back needs some sort of spoiler/kamback, and maybe extend the spoiler on the rear.
Front wasn't as bad as I expected it would be. Turbulence around the A-pillar, a high pressure zone in front of the windscreen. I think the new mirrors do help quite a lot.
Wat do you think? I have some short clips, if anyone is interested i'll put them on youtube.
Old 06-03-2014, 12:21 AM   #20 (permalink)
Gotta hate what Europe is turning into by the so-called environmentalists who seem to ignore the environmental and social benefits from the enhanced resilience to lower-grade alternative fuels in the old Diesel beaters.
