09-05-2012, 07:22 PM
Mg midget mk4
I was wondering if any of you happen to know of a windshield that will fit the mg midget mk4 that isnt quite so vertical; i think the main reason its drag coefficient is so terrible is the windshield.
The mk4 is listed as 55 in wide; so the problem is that a majority of cars are wider then it, and the ones i found that are narrower dont look very aerodynamic.
09-06-2012, 06:58 PM
4-season?
If you didn't drive the car year round,you could remove the windshield and convert to a spider,with a plex half-bubble in front of just you.You'd be required to wear eye protection as with a motorcycle,and you'd have no wipers.She'd be for fare weather only.
Combined with a head fairing,you could recover some of your fuel.Look at early racing Porsche 356s.
09-06-2012, 09:26 PM
you might try the 63-67 nissan fairlady they had an aero ish windshield and frame that was removable with 4 bolts I dont know if it will fit ,but its a starting point
09-06-2012, 10:32 PM
Have you measured a Miata?
09-06-2012, 11:18 PM
Do more with less
Although the CD might not be ideal the CDA is probably good. It has to have one of the smallest frontal areas of any car on the road. The seating position is very low. Make a hard top for it and enjoy.
– Noah Webster, 1787
09-07-2012, 03:12 AM
yes
the fairlady looks like its a bit too wide by 2 inches.
the miata is definatly too wide as well.
wonder if ill have to cut the glass to size.
09-07-2012, 05:19 AM
SuperBeetle backlight, 36" wide, with an aluminum extrusion frame.
Otherwise, what aerohead said.
09-07-2012, 11:47 PM
backlight
The backlight will be safety glass,but not laminated safety glass.If it gets caught during an annual safety inspection they'll red flag it,as it won't be DOT certified as a windshield.That would really suck after going to all the trouble.
We can't even run this sort of thing at Bonneville.Rats!
How wide is the new VW 1-liter car's windshield? If it goes to production it will be laminated.It's very narrow and very low drag.
09-08-2012, 04:57 AM
#9 (permalink)
I agree.
On the other hand I live in a state where I've owned vehicles for 50 years and I've never been subjected to a safety or emissions inspection (discounting roadside stops).
Reason: bad math
09-08-2012, 07:33 AM
#10 (permalink)
Do more with less
If it must be more swoopy then tip the stock unit back more.
