Old 11-25-2022, 02:19 AM   #61 (permalink)
So a belt or chain around both inner CV joints...
[citation needed]
"We're deeply sorry." -- Pfizer
Old 11-25-2022, 07:28 PM   #62 (permalink)
[citation needed]
Some British Fords from the '80s and '90s with 2-channel ABS only to the front wheels had a similar arrangement for its sensors.
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
freebeard (11-25-2022), seuadr (11-28-2022)
Old 11-26-2022, 11:26 AM   #63 (permalink)
[citation needed]
HowTH do I site references to something thats never been done before..?
This is what I know:
The inner CV's outer shell 'stands still' relative to the engine and gearbox, rotation excepted.
So if you can find space to mount said hub motors to that/them and a sprocket on the CV's outer shell; you're good from an engineering standpoint.
The chain or belt tension will put an extra load on the bearing the CV/s fit into, but I'd be willing to bet they can handle it.
As said: Just an idea based on my research and thinking on the:
"How to easily electric assist a car".
If anyone has a better suggestion; I'm all ears!
Er...
Perhaps you're trying to picture a single chain (driven by one motor) around both inner CVs?
I'm seeing one motor and chain per CV/side.
The Following 2 Users Say Thank You to Logic For This Useful Post:
freebeard (11-26-2022), seuadr (11-28-2022)
Old 11-27-2022, 12:06 AM   #64 (permalink)
I'd take a look at the internally-mounted front brakes of some ancient Citroëns such as the 2CV for packaging references.
seuadr (11-28-2022)
Old 11-27-2022, 01:47 PM   #65 (permalink)
Sorry that was me being lazy. Allow me to try:
http://www.alfabb.com/attachments/al...nd-jpg.131000/
Any transaxle with inboard disk brakes. You could mill non-ventilated rotors into sprockets.
edit: As soon as I posted I see cRiPpLe_rOoStEr covered it. I picked the Alfa for it's DeDion axle.
2nd edit:
I also picked that picture for a particular implementaion of the Watt's four-bar linkage, the Panhard rod.
seuadr (11-28-2022)
Old 11-28-2022, 07:09 AM   #66 (permalink)
i didn't realize that was a "thing" seems like it'd be a pain to do the brakes, but, i wonder what advantages it might offer?
Old 11-28-2022, 11:29 AM   #67 (permalink)
Less unsprung weight.
Old 12-02-2022, 02:07 AM   #68 (permalink)
Not sure exactly why the Humvee resorted to internal brakes, but most likely unsprung weight was not the reason. Most likely another advantage was the brake rotors being at a safer location regarding road debris, also accounting the increased riding height provided by the portal axles.
Old 12-02-2022, 03:03 PM   #69 (permalink)
2nd edit:
See the 6 bolts holding the inner CV on:
Thats where I'd bolt a sprocket with an appropriately sized hole in the middle and with the correct tooth ratio to get the desired (top) speed you want from the elec assist.
The hub motors: Wherever there's space.
From what I recall of rear boxed Alfas; Probably mod th chassis to ,make room under the back seat for them..?
Mounted to the gearbox naturally.
Old 12-04-2022, 01:49 AM   #70 (permalink)
As you would be supposed to service the hub motors less often than the brakes, placing them internally makes sense.
